Replace TeeTree after Zoom
TeeTree VCL for Borland Delphi and C++ Builder.
mivchart
Post by mivchart » Tue May 18, 2010 2:53 pm
Hi ,
D2007 + VLC 8.04
How to keep the tree on Top an Left = 0 after Zooming ??
I find the code But, without result
{ var tmpPos : Integer;
tmpPos := (Tree1.HorzScrollBar.Max-Tree1.HorzScrollBar.Min) div 2;
tmpPos := tmpPos - (Tree1.HorzScrollBar.PageSize div 2);
Tree1.View3DOptions.HorizOffset := -tmpPos;
E
Re: Replace TeeTree after Zoom
Post by Yeray » Thu May 20, 2010 11:45 am
Hi mivchart,
I'm not sure what are you exactly trying to align on the top-left. Could you please send us a complete and simple example project we can run as-is to reproduce the issue here?
mivchart
Post by mivchart » Fri May 21, 2010 6:51 am
it's simple, i join project with post
exmple code =========================
procedure TForm1.Track_ZoomChange(Sender: TObject); //Not result !
// Change zoom
Tree1.View3DOptions.Zoom:=Track_Zoom.Position;
LabelZoom.Caption:=TeeStr(Tree1.View3DOptions.Zoom)+'%';
//<<<< HERE when i Zoom, the tree create offset on TOP and Left, it's no goodg for user !!!
procedure TForm1.BtAlignTopLeftClick(Sender: TObject);
Track_Zoom.Position:=100; //If Zoom return in 100% > ok Vetical Ofset =0
Tree1.View3DOptions.Zoom:=100; //<<< How take for align on TOP and LEFT=0 if Zoom <> 100%
Tree1.View3DOptions.HorizOffset:=0;
Tree1.View3DOptions.VertOffset:=0;
TreeZoom.zip
Porject exmple Zoom tree
(32.39 KiB) Downloaded 1555 times
Post by Yeray » Mon May 24, 2010 2:59 pm
Hi mivchart,
Apparently it seems to be a problem with the Horizontal and Vertical scrollbars that should be reset to 0. The problem then is that the Position property is read-only so the following code isn't accepted:
  // Change zoom
  Tree1.Draw();
  Tree1.Draw();
procedure TForm1.Tree1AfterDraw(Sender: TObject);
  Tree1.VertScrollBar.Position:=0;
  Tree1.HorzScrollBar.Position:=0;
But it will be accepted if you change TTreeScrollBar's Position property definition TeeTree.pas from:
property Position:Integer read GetPosition;
To this:
property Position:Integer read GetPosition write SetPosition default 0;
I've seen that you are source code customer so, please, try with the changes above and tell us if it works better.
Also note that 8.04 is not the latest version available so, please, try with the latest (8.07).
mivchart
Post by mivchart » Tue May 25, 2010 7:07 am
sorry , but no result.
i have changed the code in unit Teetree.pas with example
i have changed my code > but without effect !
procedure TFrameEfcTree.Tree1AfterDraw(Sender: TObject);
Tree1.VertScrollBar.Position :=0;
Tree1.HorzScrollBar.Position :=0;
My request is simple, if I zoom I want to keep the position and left top = 0 = 0 of my tree for the good look user ?
Post by Yeray » Tue May 25, 2010 7:42 am
Hi mivchart,
Have you assigned the AfterDraw event correctly? I haven't posted the code because I've created it at design time.
mivchart
Post by mivchart » Tue May 25, 2010 7:59 am
i have this code in my form
Tree1.VertScrollBar.Position :=0;   //no result !!
procedure TFrameEfcTree.Tree1Zoom(Sender: TObject);
  if not ZoomChange then begin
    // Show % percent of zoom in label
    Tree1.draw();
    Tree1.draw();
in my unit teetree, only
    property Position:Integer read GetPosition write SetPosition default 0;   //MD  4.215
Post by Yeray » Tue May 25, 2010 9:52 am
Hi mivchart,
I see you've included the Tree1Zoom event that wasn't in the project you sent.
I've added this to the defect list to be revised in future releases (TV52014910) but in the meanwhile please, try with event like Zoom, AfterDraw,... as you do.
I've seen that the Horizontal and Vertical ScrollBars are changing their Min and Max values when zooming. The problem could come from here.
