v2010 View3DOptions.VertOffset changed behavior
Bert Kreisel
Post by Bert Kreisel » Wed May 05, 2010 11:26 am
In VCL V2010 a 3D Pie loaded from a file has a wrong vertical position (too much at bottom). The same chart (with same View3DOptions.VertOffset=24) loaded with VCL V8.06 has the right position. For correct vertical position with v2010 we have to change View3DOptions.VertOffset=-14. We have manny chart configurations saved at our clients which won't be completly visible after update to V2010. Could you please help us?
Bert Kreisel
Re: v2010 View3DOptions.VertOffset changed behavior
Post by Narcís » Thu May 06, 2010 8:33 am
Hi Bert,
Could you please attach a simple example project or a *.tee file we can run "as-is" to reproduce the problem here?
Bert Kreisel
Post by Bert Kreisel » Fri May 07, 2010 2:17 pm
Hi Narcis,
i attached v806.tee in v806.zip.
Bert Kreisel
v8_06.zip
(1.81 KiB) Downloaded 281 times
Post by Yeray » Wed May 12, 2010 12:11 pm
Hi Bert,
We can't load the tee file you've attached above. It gives us a "Class TCopyLastFunction not found" error.
Could you please send us an example we can run as-is here of how to create a tee file like this, or try to send us another tee file without this dependence?
Note that you can export your chart as text so the configuration can be revised with notepad or similar.
Bert Kreisel
Post by Bert Kreisel » Mon May 17, 2010 1:10 pm
i can load the file in TeeChartOffice. Anyway i attached v8_6.tee in v8_6.zip. It's an export as text where I deletet the TCopyLastFunction.
Bert Kreisel
8_6.zip
(1.81 KiB) Downloaded 289 times
Post by Narcís » Mon May 17, 2010 1:56 pm
Hi Bert,
Thanks for the file. I could reproduce the issue here added it (TV52014892) to the defect list to be investigated.
