Bar Charts - serialization
UserLS
Post by UserLS » Sat Mar 27, 2010 5:03 am
I am back to template files. This time I have a bar graph, set its style to arrow or ellipse, to make it pretty - use gradient fill. Now save it to template file and then reload... gradient is gone and I am back to solid color.
By the way, if I am using ellipse style and set gradient direction to FromCenter or Radial, than only those ellipses, which are above the origin line will be filled with colors, the others will be empty (same applies to horizontal bars)!
Re: Bar Charts - serialization
Post by Sandra » Tue Mar 30, 2010 10:46 am
Hello UserLs,
I could reproduce your problems using last version of TeeChart .Net. I have added these in bug list with numbers [TF02014764] and [TF02014766] We will try to fix these for next versions of TeeChart .Net.
Post by Sandra » Fri Sep 24, 2010 2:37 pm
Hello UserLs,
I inform that we’ve fixed the bug with number (TF02014766). Now works fine.
