How to define picture size in chart editor for export?
ulibru
Post by ulibru » Sun Mar 14, 2010 3:50 pm
I can open the chart editor during runtime and export a chart as e.g. a bmp picture.
The editor window shows a picture size automatically derived from chart.width and chart.height
In the according edit fields it is possible to manually edit the width and heigth data.
How to fill these parameters by the application program? To set the chart dimension in the OnShow event of the chart editor does not help as it also changes the chart size on the screen.
Thanks for any advice
Uli
Re: How to define picture size in chart editor for export?
Post by Yeray » Mon Mar 15, 2010 9:42 am
Hi Uli,
You could change the chart's width and height before opening the editor and not allowing the chart to be redrawn with autorepaint=false:
uses Series, TeeEdit;
  Chart1.Width:=300;
  Chart1.Height:=200;
  with Chart1.AddSeries(TBarSeries.Create(self)) do FillSampleValues();
var oldWidth, oldHeight: Integer;
  Chart1.AutoRepaint:=false;
  oldWidth:=Chart1.Width;
  oldHeight:=Chart1.Height;
  Chart1.Width:=600;
  Chart1.Height:=400;
  with TChartEditor.Create(self) do
    Chart:=Chart1;
    Execute;
  Chart1.AutoRepaint:=true;
  Chart1.Width:=oldWidth;
  Chart1.Height:=oldHeight;
ulibru
Post by ulibru » Tue Mar 16, 2010 7:21 am
Uli
