Highlight series when mouse is over item in legend
TestAlways
Post by TestAlways » Wed Mar 10, 2010 6:31 pm
Occasionally my app users will have a large number of bar-series in a chart, I've seen something in the order of 20. (While I would run the illustrations differently, I'm not in the business of telling them how to run their business--for some of them, this is "critical").
In any case, I would like to be able to highlight a series when the mouse moves over the name in the legend. Is anything like that possible?
Thank you,
Ed Dressel
Re: Highlight series when mouse is over item in legend
Post by Yeray » Thu Mar 11, 2010 3:14 pm
Hi Ed,
You could use OnMouseMove event doing something as following (or OnClickLegend):
uses series;
var AntClickedIndex: Integer;
var i: Integer;
  Chart1.View3D:=false;
  for i:=0 to 19 do
    with Chart1.AddSeries(TBarSeries.Create(self)) do
      FillSampleValues();
      Marks.Visible:=false;
      Color:=OperaPalette[i mod 12];
  AntClickedIndex:=-1;
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
  Y: Integer);
var ClickedIndex: Integer;
  ClickedIndex:=Chart1.Legend.Clicked(X,Y);
  if (ClickedIndex > -1) then
    if (AntClickedIndex <> ClickedIndex) then
      if (AntClickedIndex > -1) then
        Chart1[AntClickedIndex].Pen.Width:=1;
        Chart1[AntClickedIndex].Pen.Color:=clBlack;
      Chart1[ClickedIndex].Pen.Width:=2;
      Chart1[ClickedIndex].Pen.Color:=clYellow;
      AntClickedIndex:=ClickedIndex;
  end
TestAlways
Post by TestAlways » Thu Mar 11, 2010 7:15 pm
This is very cool. I didn't ask the question for a long time because I didn't think it was close to possible. Thank you!
You have the following LOC in your demo:
Is this an indication that it is not supported in 3D? (I can get it to work in a demo, but it looks like changing the pen in my app with 3D on causes other series lines to be drawn with the highlighting).
Ed Dressel
Post by Yeray » Fri Mar 12, 2010 4:52 pm
Hi Ed,
It works too in 3D, simply remove that sentence and you'll see it.
Excuse me if I confused you, it's only that I use to check the things first in 2D...
TestAlways
Post by TestAlways » Fri Mar 12, 2010 6:34 pm
Huh... in a demo I created, it works fine. I put it in my application, and strange things occur. Here is an example of the chart in my software with only one series with the pen visible and set to yellow:
You can see that more than one series is highlighted with yellow, but only Social Security should be.
My code is a little different, but not much:
procedure TMyUnit.chrtIncomeSourcesMouseMove(Sender: TObject;
var
  lClickedIdx: Integer;
  lSeries: TChartSeries;
  lClickedIdx:= chrtIncomeSources.Legend.Clicked(X,Y);
  if (FYearIdx = -1) and
    (lClickedIdx > -1) then
    if (FAntClickedIndex <> lClickedIdx) then
      ClearHighlightedSeries;
      lSeries := chrtIncomeSources[lClickedIdx];
      lSeries.Pen.Width := 2;
      lSeries.Pen.Color:= HIGHLIGHT_COLOR;
      lSeries.Pen.Visible := True;
      FAntClickedIndex := lClickedIdx;
  end
  if (FAntClickedIndex > -1) then
procedure TMyUnit.ClearHighlightedSeries;
var
  {$ifopt C+}
  I: integer;
  {$endif}
  if InRange(FAntClickedIndex, 0, chrtIncomeSources.SeriesCount-1) then
    lSeries := chrtIncomeSources[FAntClickedIndex];
    lSeries.Pen.Color := DEFAULT_PEN_COLOR;
    lSeries.Pen.Width := 1;
    lSeries.Pen.Visible := false;
  {$ifopt C+}
  for I := 0 to chrtIncomeSources.SeriesCount - 1 do
    if not SameText(chrtIncomeSources[I].Title, 'Income Needed') then
     Assert(not chrtIncomeSources[I].Pen.Visible, 'Pen visible for ' + chrtIncomeSources[I].Title);
  {$endif}
I added the assert to check if multiple series have visible pens. But the assert is never fired (and it is called).
Am I doing something wrong? (I have a bit more code in my app to configure the TChart that I did not put in the demo that does work fine).
Ed Dressel
Post by Yeray » Mon Mar 15, 2010 9:27 am
Hi Ed,
The most significant difference I can see between your picture and the demo I made is that your bars are stacked but with adding it and even using your code, I don't reproduce the "all-selected" problem. Here is the complete code I'm using that seems to work fine here:
uses series;
var FAntClickedIndex: Integer;
var i, j: Integer;
  for i:=0 to 8 do
    with Chart1.AddSeries(TBarSeries.Create(self)) as TBarSeries do
      for j:=0 to 30 do Add(random*100+100);
      MultiBar:=mbStacked;
  Chart1.AddSeries(TLineSeries.Create(self));
  Chart1[Chart1.SeriesCount-1].FillSampleValues();
  FAntClickedIndex:=-1;
  Y: Integer);
  procedure ClearHighlightedSeries;
  var lSeries: TChartSeries;
    if (FAntClickedIndex >= 0) and (FAntClickedIndex < Chart1.SeriesCount) then
      lSeries := Chart1[FAntClickedIndex];
      lSeries.Pen.Color := clBlack;
var
  lClickedIdx:= Chart1.Legend.Clicked(X,Y);
  if (lClickedIdx > -1) then
      lSeries := Chart1[lClickedIdx];
      lSeries.Pen.Color:= clYellow;
  end
And here is the result I get with TeeChart v8.06:
Is the code above giving the same result than me?
What TeeChart version are you using?
TestAlways
Post by TestAlways » Mon Mar 15, 2010 10:32 am
8.04
Thanks. Your demo works fine. I'm trying to figure out the difference. I do some configuration of the chart and series in my app, but moving that into the demo has not reproduced the problem. I am a bit tight on time, but will look at this again in a few days.
TestAlways
Post by TestAlways » Mon Mar 15, 2010 12:35 pm
I found some old ode in my app that seems to cause the problem--aChart is passed in a a paramter:
var
  lHandle: Integer;
  lHandle := aChart.Handle;
  SetWindowLong(lHandle, GWL_EXSTYLE, GetWindowLong(lHandle, GWL_EXSTYLE)
    and not WS_EX_CONTROLPARENT);
AFAICR Peter Below gave me the code in a Delphi new group, but that is going to be a lot of years ago now. I did not document what it was for. Any ideas what this might do?
Ed Dressel
Post by Yeray » Tue Mar 16, 2010 4:32 pm
Hi Ed,
I've seen that Peter Below has already answered you here :)
If you still have problems with it, please don't hesitate to let us know.
TestAlways
Post by TestAlways » Wed Mar 17, 2010 4:53 pm
Well, I spoke to quick. The problem is still there and I am still trying to reproduce it in a demo.
TestAlways
Post by TestAlways » Wed Mar 17, 2010 8:31 pm
Finally got it. Had to copy the chart from the other version to this one. It is in the attached demo--I included the source code (from D2007, TChart Pro 8.04).
If you move your mouse over the "Series #5" caption in the legend, more than one series highlights.
What is causing this?
Ed Dressel
Post by Yeray » Thu Mar 18, 2010 1:15 pm
Hi TestAlways,
I don't find the demo you mention. If you sent it through the upload page, could you please tell us the domain of the mail address you sent the files with?
TestAlways
Post by TestAlways » Thu Mar 18, 2010 1:28 pm
Oops... here is a link to the demo:
http://www.tbinc.com/misc/LegendHighlightSeries2.zip
Post by Yeray » Thu Mar 18, 2010 2:33 pm
Hi TestAlways,
I've seen in the exe you've sent that moving the mouse over "Series #5" all the series seem to be selected. I've also seen that if you move the mouse over the other series in the legend, the series selected in the chart are more correct as more series you've been selected, and finally when you've selected all the series, all them work fine, even for "Series #5".
The problem could be in the index returned by the Chart1.Legend.Clicked(X,Y) call in the OnMouseMove event.
Then I compiled the project with the actual v8.06 and couldn't reproduce the problem. So the first I'd recommend would be to update the component to the latest maintenance release, if possible.
Another thing you could check would be adding the following statement in your OnMouseMove event, after the clicked call, to check the if the value returned is correct at any time:
  Chart1.Title.Text.Text:=IntToStr(lClickedIdx);
TestAlways
Post by TestAlways » Thu Mar 18, 2010 5:55 pm
I upgraded to 8.06 and the problem is still there., but I found it... It is the anti-alias tool that is causing the problem.
I reproduced the problem after removing all of the configuration, but the problem goes away if I disable the anti alias tool. Here is a sample project:
