Adding Multiple Series using Tee Chart in Reporting Services
I'm current using Steema TeeChart for .Net v3 in Reporting Services 2005. I face problem adding multiple series in a chart region in reporting services. Does TeeChart support multiple series in reporting services ? If yes, how should I do so ? Please feedback as soon as possible. Thanks.
Re: Adding Multiple Series using Tee Chart in Reporting Services
Hi gizian,
I don't think there should be any problem. Do you have the same problem in a simple WinForms application? If the problem persists can you please attach a simple example project we can run "as-is" to reproduce the problem here?
Hi, attached is the simple TeeChart project that uses a dataset to plot 2 series. There are error when preview at reporting services:
[rsDuplicateScopeName] More than one data set, data region, or grouping in the report has the name ‘teeChart1_X’. Data set, data region, and grouping names must be unique within a report.
[rsDuplicateScopeName] More than one data set, data region, or grouping in the report has the name ‘teeChart1_Y’. Data set, data region, and grouping names must be unique within a report.
[rsWrongNumberOfDataRows] The custom reportitem ‘teeChart1’ contains a wrong number of DataRow elements. 3 DataRow elements are expected, because there must be as many DataRow elements as there are leaf-node DataGroupings (i.e. DataGrouping without sub-groupings).
Build complete -- 3 errors, 0 warnings
Kindly advise. Thanks.
- TeeChartReport.zip
- TeeChart project file
- (8.88 KiB) Downloaded 192 times
Hi, any updates on this ?
Hi gizian,
We are studying it and we'll be back to you as soon as possible.
If you are interested in priority support service you may be interested in our Pro-Support program.
