CustomPoint Serialization Error
noaksey
Post by noaksey » Mon Jan 18, 2010 12:54 pm
I'm using VS2008 SP1 and TeeChart 4.0.2009.28593
I've created a control using TeeChart, but when adding the control to a form I get an error with CustomPoint -- "CustomPoint is not marked as serializable.
I've created a small example that shows the problem. Drag the "Tester" tool from the toolbox onto Form1
Thanks for any help.
SerialisationProblem.zip
(65.85 KiB) Downloaded 895 times
Re: CustomPoint Serialization Error
Post by Yeray » Tue Jan 19, 2010 3:27 pm
Hi noaksey,
I've reproduced it with your project and added it to the defect list to be fixed in future releases (TF02014643).
Post by Yeray » Thu Jan 28, 2010 12:15 pm
Hi noaksey,
As an update, we've found that to get it to work, you should use the MyPoints class instead of the Points class as in the example:
   public class MyPoints : Points
     public MyPoints() : this((Chart)null) { }
     public MyPoints(Chart c)
       : base(c)
       base.InternalUse = true;
