Switch programatically between HorizontalBar, and Bar
Doogie
Post by Doogie » Sun Nov 29, 2009 1:22 pm
Is it at all possible, to toggle the chart between Horizontal Bar, and Bar, with the same data, but differently orientated, according to user preference.
If possible, how do I achieve this in code?
I want to rotate this from HorizontalBar to Bar.
Re: Switch programatically between HorizontalBar, and Bar
Post by Yeray » Mon Nov 30, 2009 9:55 am
Hi Doogie,
Yes, you could use ChangeSeriesType function. For example:
var i: Integer;
    tmp: TChartSeries;
    tmp:=Chart1[i];
    if Chart1[i] is THorizBarSeries then ChangeSeriesType(tmp,TBarSeries)
    else ChangeSeriesType(tmp,THorizBarSeries);
