Panel BackImage Filters
Otokon
Post by Otokon » Thu Sep 03, 2009 12:03 pm
I would like to change the brightness of a filter I added to a panel back image, how do I go about doing so?
TChart1.Panel.BackImage.LoadImage(@"C:\logo.jpg");
TChart1.Panel.BackImageInside = true;
TChart1.Panel.BackImage.Mode = TeeChart.EBackImageMode.pbmCenter;
TChart1.Panel.BackImage.Filters.Add(TeeChart.EFilterClass.fcBrightness);
TChart1.Panel.BackImage.Filters.Add(TeeChart.EFilterClass.fcGrayScale);
Re: Panel BackImage Filters
Post by Narcís » Thu Sep 03, 2009 12:47 pm
Hi Otokon,
Yes, you can do this:
    TChart1.Panel.BackImage.Filters.Item(0).asBrightness.Amount = 50
Otokon
Post by Otokon » Fri Sep 04, 2009 7:03 am
Thank you for the reply. I had to use "get_Item" and not "Item", but its working correctly now.
TChart1.Panel.BackImage.Filters.get_Item(0).asBrightness.Amount = 35;
Otokon
Post by Otokon » Fri Sep 04, 2009 9:55 am
How do I set the series border visibility to true with code?
Post by Narcís » Fri Sep 04, 2009 10:02 am
Hi Otokon,
If your series is a Line series try using this:
			axTChart1.Series(0).asLine.LinePen.Visible = true;
Hope this helps!!
Otokon
Post by Otokon » Fri Sep 04, 2009 10:23 am
Hi Narcís,
I tried your code, but I'm still not able to set border visibility to true. I'm able to set Outline visibility though.
//works
MyChart.Series(0).asLine.Outline.Visible = true;
//dont work
MyChart.Series(0).asLine.LinePen.Visible = true;
Any suggestions?
Post by Narcís » Fri Sep 04, 2009 10:31 am
Hi Otokon,
Try this then:
			axTChart1.Series(0).Pen.Visible = false;
Otokon
Post by Otokon » Fri Sep 04, 2009 10:59 am
Hi Narcís,
Sorry man. But it still doesn't work.
Post by Narcís » Fri Sep 04, 2009 11:03 am
Hi Otokon,
Otokon
Post by Otokon » Fri Sep 04, 2009 11:34 am
Hi Narcís,
The problem was at my side, "TChart1.Series(0).Pen.Visible = true;" does work.
Thanks!!!!
