hi
when saving a chart to stream im using the following code:
SaveChartToStream(Chart1,strm,TRUE,TRUE);
strm : TMemoryStream;
when loading it back im using the following code:
LoadChartFromStream(TCustomChart(Chart1),strm);
i have to typecast to TCustomChart or else it wont compile
when the code is executed i get the attached error.
the error is internal and is visible only when running in debug mode, running it from outside of delphi nothing is shown to the user.
anyway, the loading is successful as if nothing happened
please advice
problem loading chart from stream
- err.JPG (17.74 KiB) Viewed 3705 times
Re: problem loading chart from stream
Hi Nati,
The following example seems to work fine here:
Could you please modify it or attach here a simple example project we can run as-is to reproduce the problem here?
uses teestore, series;
Chart1.RemoveAllSeries;
procedure TForm1.Button2Click(Sender: TObject);
strm.Position := 0;
strm := TMemoryStream.Create;
Chart1.AddSeries(TPointSeries.Create(self));
Chart1[0].FillSampleValues(25);
