Silverlight Chart resizing
I am unable to get the Silverlight TChart control to resize when the browser resizes. I have tried to set TChart control's HorizontalAlignment and VerticalAlignment to Stretch with no luck. I have attempted to set TChart control's Height and Width when it's containing grid resizes but the change has no effect on the dimensions of the control. What am I doing wrong?
Re: Silverlight Chart resizing
Hi Farsider,
I'm afraid this is a bug (TW24014257) which I have added to the defect list to be fixed for future releases.
Hi Farsider,
We have investigated the issue and we are not sure if this is about Teechart.Silverlight.dll or about the use of the Silverlight framework. I attach an example using a standard Silverlight UserControl which exibits exactly the same behaviour as Teechart. Can you please have a look at this project and check if you can get resize to work with the standard SilverLight UserControl?
- TeeChartv4Silverlight_2008.zip
- (8.58 KiB) Downloaded 377 times
