Legend Palette issue
johnnix
Post by johnnix » Thu Jun 04, 2009 7:52 am
I use the latest TChart Pro (sources) and I noticed an issue with the Legend Palette tool. I place a TChart in a form and add an IsoSurfaceSeries and a Legend Palette. When I customize the appearance of the Legend (e.g. labels format, text etc) it appears ok in design mode. When I run the software the Legend is displayed using the default settings. Am I doing something wrong here?
Post by Yeray » Thu Jun 04, 2009 9:15 am
Hi johnnix,
Could you please specify what properties are you seeing that aren't saved correctly? Here, in a first test, I can "only" reproduce it with the axes.
johnnix
Post by johnnix » Thu Jun 04, 2009 9:19 am
Hello Yeray,
I only tested it with almost all axes properties and I can confirm that none is saved :) I need to alter these properties for my project so I if there is a quick fix for this in the sources I will be very happy to hear from you
Post by Yeray » Thu Jun 04, 2009 12:08 pm
Hi johnnix,
Then, I'll add the bug (axes properties changes at design time from Legend palette have no effect) to the wish list to be fixed asap (TV52014212).
