One Axis line not shown
Cogito
Post by Cogito » Tue May 26, 2009 12:33 pm
I use a line chart and have defined axis under the Ticks tab for the bottom axis as solid line. Also I've defined a fixed minimum and maximum value for scale for the left axis (min: 85; max: 130). The problem is now, that the chart doesn't show me the top line (beside the value 130) of my chart and I doesn't find an option to correct that. The highest value which is shown is 127, maybe therefore the chart component doesn't show the line?! Could anybody help me?
Post by Yeray » Tue May 26, 2009 1:42 pm
Hi Cogito,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
Cogito
Post by Cogito » Wed May 27, 2009 7:09 am
9348257 wrote:Hi Cogito,
OK, I've created a short sample and uploaded it. You can see the effect, because the line beside the value 130 is not shown...
By the way there's another definition problem in another chart. I use also a bar chart and want to show the bar values above the bars, but the distance between the value and the bar is quite big. Which parameter do I have to adjust to correct this distance?
Post by Yeray » Wed May 27, 2009 8:50 am
Hi Cogito,
1. I can see in your table a minimum for Reihe1 as 72,471 (OID 137). And other values lower to 85 (concretely starting at OID 131). I think you should revise it, set left axis as automatic or call SetMinMax to adjust your Left axis.
2. I think you are looking for something like this:
Series1.Marks.ArrowLength := 5;
Cogito
Post by Cogito » Wed May 27, 2009 10:15 am
I can't define left axis as automatic, because it's a requirement from the user! He wants to have one line under and above the chart.
I've the same behaviour in a bar chart but in this chart it works... :roll:
Edit: As you can see, the values under 85 are for another product (another ISIN), therefore these are shown in another chart...
Post by Yeray » Wed May 27, 2009 11:56 am
Hi Cogito,
If now I understand better, you mean that the grid line at 130 isn't drawn and you want it, isn't it? If so, you could do add more maximum offset as follows:
IndexChart.Axes.Left.MaximumOffset := 10;
