Native template files.
Elis
Post by Elis » Fri Feb 13, 2009 10:09 am
I found this in your support group "You can use TeeChart's native template files for that. You'll find more information in Tutorial 12 - Exporting and Importing Charts. Tutorials can be found at TeeChart's program group."
We have installed TeeChart ver 8.02 Source code. I checked my installed program group - no tutorials there.
We then then downloaded the documentation offered from the steema website but when we search for "export settings" we get "The adress is not valid" error message.
I have looked into all the available demos (for download) - but can not find any Tutorial 12.
There is no tutorial in the directory where we installed TeeChart. How do I find this tutorial???
Post by Yeray » Fri Feb 13, 2009 11:26 am
Hi Elis,
To install the docs, tutorials and examples you need to install the binary installer (without sources) and then install the binary installer (with sources).
If you are a source code customer, you can use the same license number to download both them.
