Datasources and null points
Ashutosh
Post by Ashutosh » Tue Jan 27, 2009 9:48 am
Hi Narcis,
I have some more queries regarding the TeeChart Activex Control v8:
1. How can I add dataset as data source for the Chart.
2. If the series gets empty or null value for a data point, how can we show a gap in the line series.
To make it more clear let's say we have 10 ponits to draw a chart for the points 1 to 4 we have some data and point 5 is blank. in that case how can we show a gap on the line and resume from point 6 onwards. We are using fast line series.
Please help as soon as possible.
Thanks and regards
Ashutosh
Post by Narcís » Tue Jan 27, 2009 11:05 am
Hi Ashustosh,
You need to do as shown in Tutorial 8 - ADO Database access. Tutorials can be found at TeeChart's program group.
This can be achieved using new TreatNulls property as shown in the What's New?\New in Series\Fast Line TreatNulls example at the features demo, also available at TeeChart's program group.
Ashutosh
Post by Ashutosh » Fri Jan 30, 2009 5:05 am
Hi Narcis,
I have uploaded an image file here http://www.steema.net/upload/ which displays a sample chart with gaps for the null values data. How can I achieve the same. Kindly note that the chart in the image is TeeChart Activex control.
Let me know in case of any more clarifications needed.
Thanks and regards
Ashutosh
Post by Yeray » Fri Jan 30, 2009 8:18 am
Hi Ashustosh,
Having the property "IgnoreNulls" to false:
TChart1.Series(0).asFastLine.IgnoreNulls = False
you should set the property "TreatNulls" as you wish. The property:
TChart1.Series(0).asFastLine.TreatNulls
And the three possible values:
tnDontPaint
tnSkip
tnIgnore
Ashutosh
Post by Ashutosh » Mon Feb 02, 2009 4:45 am
Hi Narcis, Yeray
This is to say you Thanks a lot for your support and suggestions. This has been relly great pleasure to work with such support which you provide.
Thanks and regards
Ashutosh Prasad
