I'm trying to receive click events when a user clicks on my color grid. I need to know where in the grid the click occurred so that I can display details relating to that cell. I've added a SeriesMouseListener and a ChartMouseListener, neither of which seems fire at any time. What steps do i need to take to receive those click events?
Thank you
ColorGrid SeriesMouseListener
Hi McMClark,
Thanks for reporting. I could reproduce the issue here and added it (TJ71013450) to the defect list to be fixed for next releases.
Thank You. Any information on when a fix will go out for this? We're dependent on the colorgrid for an upcoming project and will have to find another solution if a fix isn't made soon.narcis wrote:Hi McMClark,
Re. Maintenance release
We will announce it shortly
To resolve the SeriesClick problem, if you are compiling from TeeChart code you can add the following method to the ColorGrid class (com\steema\teechart\styles\ColorGrid.java):
public int clicked(int X, int Y)
int i, tmpResult = -1;
double tmpDecAmount;
int Result = -1;
int zIndex = -1;
double XPos = super.getHorizAxis().calcPosPoint(X);
double YPos = super.getVertAxis().calcPosPoint(Y);
if (this.centered)
tmpDecAmount = 0.5;
tmpDecAmount = 0.0;
if (!this.getIrregularGrid())
double YDif = (YPos + tmpDecAmount) - this.getZValues().getMinimum();
if (YDif >= 0f)
i = (int)(YDif);
i = -1;
if ((i >= 0) && (i < this.getNumZValues()))
zIndex = i;
if (zIndex != -1)
double XDif = (XPos + tmpDecAmount) - this.getXValues().getMinimum();
if (XDif >= 0f)
i = (int)(XDif);
i = -1;
if ((i >= 0) && (i < this.getNumXValues()))
tmpResult = this.getIndex(i + 1, zIndex + 1);
return tmpResult;
if (super.getXValues().getCount() > 0)
int num = this.getNumZValues() - 1;
i = 0;
if (num >= i)
num++;
do
if ((( (this.getZValues().getValue(i) - tmpDecAmount) <= YPos)
&& ((this.getZValues().getValue(i + 1) - tmpDecAmount) > YPos))
|| (((i == (this.getNumZValues() - 1))) && (((this.getZValues().getValue(i) - tmpDecAmount)) >= YPos)))
zIndex = i;
break;
i++;
while (i != num);
if (zIndex != -1)
int num2 = this.getNumXValues() - 1;
i = 0;
if (num2 < i)
return Result;
num2++;
do
if ((((this.getXValues().getValue(i * this.getNumZValues()) - tmpDecAmount) <= XPos)
&& ((this.getXValues().getValue((i + 1) * this.getNumZValues()) - tmpDecAmount) > XPos)) || (((i == (this.getNumXValues() - 1)))
&& (((this.getXValues().getValue(i * this.getNumZValues()) - tmpDecAmount)) >= XPos)))
return (zIndex + (i * this.getNumZValues()));
i++;
while (i != num2);
return Result;
well, I must be doing something wrong, I still get no click events. Here's my code. I did add the click method to the colorgrid class. I know I'm using the right JAR b/c the new method is callable from the code that references it.
ColorGrid cg = new ColorGrid(tChart1.getChart());
cg.addSeriesMouseListener(new ColorGridMouseAdapter());
class ColorGridMouseAdapter extends SeriesMouseAdapter
@Override
public void seriesClicked(SeriesMouseEvent arg0) {
System.out.println(arg0.getValueIndex());
@Override
public void seriesEntered(SeriesMouseEvent arg0) {
super.seriesEntered(arg0);
@Override
public void seriesExited(SeriesMouseEvent arg0) {
super.seriesExited(arg0);
thanks for your help.
@Override
@Override
@Override
Hi McMClark,
It works fine for us here using this code:
And implementing the event like this:
Could you please check if that works for you?
ColorGrid colorGrid1 = new ColorGrid(myChart.getChart());
colorGrid1.fillSampleValues();
myChart.addMouseListener(new java.awt.event.MouseListener() {
public void mouseClicked(MouseEvent e) {
myChartMouseListened(e);
public void mouseEntered(MouseEvent e) {
public void mouseExited(MouseEvent e) {
public void mousePressed(MouseEvent e) {
public void mouseReleased(MouseEvent e) {
private void myChartMouseListened(java.awt.event.MouseEvent e) {
int index = myChart.getSeries(0).clicked(e.getX(),e.getY());
myChart.getHeader().setText(String.valueOf(index));
