Line chart x axis labels repeating
Chen
Post by Chen » Wed Oct 08, 2008 6:26 pm
package com.amd.ngeda.chart.teechart;
import javax.swing.JFrame;
import javax.swing.JPanel;
import com.steema.teechart.styles.Line;
public class Test {
JFrame frame = new JFrame();
JPanel panel = new JPanel();
panel.setSize(600, 600);
TChart chart = new TChart();
panel.add(chart);
// [(1), (3), (10)]
// [(1), (2), (3), (10)]
// [(1), (3)]
// [(1), (2), (3), (4), (7), (8), (9), (10)]
// [(1), (2), (3), (7), (10), (15)]
// [(1), (3), (4)]
// [(1), (2), (3), (4), (7), (10)]
// [(1), (2), (3), (4), (7), (8), (10)]
// [(1), (2), (3), (4), (10), (15)]
Line fastLine = new Line(chart.getChart());
fastLine.add(2, ""+1);
fastLine.add(3, ""+3);
fastLine.add(4, ""+10);
Line fastLine11 = new Line(chart.getChart());
fastLine11.add(1, ""+1);
fastLine11.add(3, ""+2);
fastLine11.add(8, ""+3);
fastLine11.add(4, ""+10);
Line fastLine1 = new Line(chart.getChart());
fastLine1.add(10, ""+1);
fastLine1.add(20, ""+3);
Line fastLine4 = new Line(chart.getChart());
fastLine4.add(10, ""+1);
fastLine4.add(20, ""+2);
fastLine4.add(20, ""+3);
fastLine4.add(20, ""+4);
fastLine4.add(20, ""+7);
fastLine4.add(20, ""+8);
fastLine4.add(20, ""+9);
fastLine4.add(20, ""+10);
Line fastLine5 = new Line(chart.getChart());
fastLine5.add(10, ""+1);
fastLine5.add(20, ""+2);
fastLine5.add(20, ""+3);
fastLine5.add(20, ""+10);
fastLine5.add(20, ""+15);
frame.add(panel);
frame.setSize(600, 600);
frame.setVisible(true);
If you run this code then you will find that x axis contains duplicate labels.
I want to use add(double, String) in my code and I do not want to see duplicate labels. Is this a bug or feature ????? OR AM I DOING SOMETHING WRONG ? Any help would be appreciated.
Varun
Post by Narcís » Thu Oct 09, 2008 9:47 am
Hi Varun,
Sorry but I'm not able to reproduce the problem here. Could you please check that your code was correctly pasted and parsed by the forums message editor? I suggest you to surround your code snippets with "code" "/code" tags.
Chen
Post by Chen » Thu Oct 09, 2008 1:00 pm
public class Test {
panel.add(chart);
// [(1), (3), (10)]
// [(1), (3)]
// [(1), (3), (4)]
frame.add(panel);
Post by Narcís » Thu Oct 09, 2008 1:43 pm
Hi Varun,
Sorry but I'm not able to reproduce the problem you mention here. Could you please send us an image of what you get and let us know the TeeChart version you are using?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Chen
Post by Chen » Thu Oct 09, 2008 2:23 pm
I have uploaded an image file to your server.
I am using 22, May 2008 version of Teechart for Java.
Varun
Post by Narcís » Thu Oct 09, 2008 2:43 pm
Hi Varun,
Thanks for the information. Sorry, I had missed repeated "10" label. Now I see which is the exact problem, each series overwrites previous series labels. Since last series (fastLine4) has less values than penultimate series (fastLine5), some labels from fastLine4 are still visible.
Which are the labels you expect to get?
Chen
Post by Chen » Thu Oct 09, 2008 2:48 pm
I want to see NO duplicate labels and a valid chart.
Sorry I did not understand your question.
If I take my example then I would like to see 1,2,3,4,7,8,9,10, 15. Am I correct? And each series would have a valid(x,y, text) point.
Varun
Post by Narcís » Thu Oct 09, 2008 3:04 pm
Hi Varun,
This doesn't make much sense to me because the way you are populating your series, only providing a Y value, is the equivalent to populating series using X and Y values as shown here:
        Line fastLine = new Line(myChart.getChart());
        fastLine.add(0, 2, ""+1);
        fastLine.add(1, 3, ""+3);
        fastLine.add(2, 4, ""+10);
        Line fastLine11 = new Line(myChart.getChart());
        fastLine11.add(0, 1, ""+1);
        fastLine11.add(1, 3, ""+2);
        fastLine11.add(2, 8, ""+3);
        fastLine11.add(3, 4, ""+10);
        Line fastLine1 = new Line(myChart.getChart());
        fastLine1.add(0, 10, ""+1);
        fastLine1.add(1, 20, ""+3);
        Line fastLine4 = new Line(myChart.getChart());
        fastLine4.add(0, 10, ""+1);
        fastLine4.add(1, 20, ""+2);
        fastLine4.add(2, 20, ""+3);
        fastLine4.add(3, 20, ""+4);
        fastLine4.add(4, 20, ""+7);
        fastLine4.add(5, 20, ""+8);
        fastLine4.add(6, 20, ""+9);
        fastLine4.add(7, 20, ""+10);
        Line fastLine5 = new Line(myChart.getChart());
        fastLine5.add(0, 10, ""+1);
        fastLine5.add(1, 20, ""+2);
        fastLine5.add(2, 20, ""+3);
        fastLine5.add(3, 20, ""+10);
        fastLine5.add(4, 20, ""+15);
Given that code, for example, you are providing different labels for X=1 (labels are: 3,2,3,2,2) therefore the later is used. Also the same happens for X=3 (labels are: 4, 10).
To achieve what you request the only solution is using custom labels adding code below to your example.
        myChart.getAxes().getBottom().getLabels().getItems().clear();
        myChart.getAxes().getBottom().getLabels().getItems().add(0.0, "1");
        myChart.getAxes().getBottom().getLabels().getItems().add(1.0, "2");
        myChart.getAxes().getBottom().getLabels().getItems().add(2.0, "3");
        myChart.getAxes().getBottom().getLabels().getItems().add(3.0, "4");
        myChart.getAxes().getBottom().getLabels().getItems().add(4.0, "7");
        myChart.getAxes().getBottom().getLabels().getItems().add(5.0, "8");
        myChart.getAxes().getBottom().getLabels().getItems().add(6.0, "9");
        myChart.getAxes().getBottom().getLabels().getItems().add(7.0, "10");
        myChart.getAxes().getBottom().getLabels().getItems().add(8.0, "15");
