theme series colors
TestAlways
theme series colors
Post by TestAlways » Thu Sep 25, 2008 5:41 pm
How do I get the series colors for a theme?
Ed Dressel
Post by Narcís » Fri Sep 26, 2008 7:35 am
Hi Ed,
Each theme uses corresponding color palette. For example, TWindowsXPTheme uses WindowsXPPalette so you can get series colours from the palette.
TestAlways
Post by TestAlways » Fri Sep 26, 2008 1:11 pm
narcis wrote:Each theme uses corresponding color palette. For example, TWindowsXPTheme uses WindowsXPPalette so you can get series colours from the palette.
But can I get the palette from the theme? Or do I have to hard code the relationship between the theme and the palette?
Post by Pep » Mon Sep 29, 2008 9:43 am
you have to hard code the relationship, as you said. You can to know the palette colors but the chart does not know which palette has assigned.
