1) Is it possible to stack line charts when not all of the x coordinates are the same?
2) Actually, I would like to just display a line series which is identical to the final result of stacking several line charts (not all having the same x values),
without having to actually stack the individual line charts. Is there a way of doing this. Finally is this also possible with area charts?
Colin
Stacked Line Charts
Hi Colin,
I'm afraid it won't work as you expect. Both Line and Area series calculate the stacked result following the series' indexes. So, the first, result point will be the result of the addition of the firsts values if stacked series. And if they don't coincide in x, it won't look as expected.
I think that you will need to calculate each result point "manually".
Hi Colin,
In that case you may be interested in having a look at the interpolation example from Narcis.
