want adapted TeeChart 7.02 for surface with value
Ideas and wishes for TeeChart
wschrabi
Post by wschrabi » Tue Jul 22, 2008 1:02 pm
Dear friends,
some time ago I bought TeeChart 7.02.
Now I have a problem, which could be solved with your TeeChart.
I want to create a 3D suface with an attribute-value in the middle of the cell. (See PDF first file)
How can I adapt your source coude so that I have an array of values to draw the BASELINE in the middle of a surface cell.
If you would charge me some money, please tell me how much it would cost when you adapt the souce 7.02 (I have bought in the past from you) with that attribute-value for each cell.
Thanks a lot for your help.
http://festplatte.aon.at/a/filemanager. ... urface.pdf
This file shows the capabilities of Teechart 7.02 with the surface and the base line. http://festplatte.aon.at/a/filemanager. ... chart7.png
But my line should not be the line from the ground to the surface but from the surface up to a defined value. Like it is shown in the PDF (1st file).
Post by Narcís » Tue Jul 22, 2008 1:19 pm
Hi wschrabi,
I'm sorry but we don't provide support for source code customizations. Anyway, I'll add your feature request to the wish-list to be considered for inclusion in future releases.
Also notice that latest v7 sources available at the client area is v7.12 release.
Regarding your technical inquiry, I can think of 2 options to achieve it using current TeeChart features:
1. Use TPoints3DSeries togheter with a TSurfaceSeries, for example:
uses TeePoin3;
var BaseLineSeries: TPoint3DSeries;
    i: Integer;
  Series1.FillSampleValues();
  BaseLineSeries:=TPoint3DSeries.Create(self);
  BaseLineSeries.Pointer.Visible:=false;
  BaseLineSeries.BaseLine.Visible:=true;
  BaseLineSeries.LinePen.Visible:=false;
  Chart1.AddSeries(BaseLineSeries);
    BaseLineSeries.AddXYZ(Series1.XValue[i], Series1.YValue[i], Series1.ZValue[i]);
2. Custom draw the baseline:
var i: Integer;
    Chart1.Canvas.LineWithZ(Series1.CalcXPos(i), Chart1.ChartRect.Bottom,
                            Series1.CalcXPos(i), Series1.CalcYPos(i),
                            Series1.CalcZPos(i));
If you want the baseline being plotted in the center of each cell you will need to perform some sort of interpolation as shown in the example here:
http://www.teechart.net/support/viewtopic.php?t=2828
Post by Narcís » Tue Jul 22, 2008 1:23 pm
Hi wschrabi,
Sorry but I misunderstood that. In that case, the only solution I can think of is that you create your own series style inheriting from TSurfaceSeries and add an additional ValueList for each cell baseline value. You'll also need to override surface's populating and drawing methods for supporting this.
wschrabi
tks
Post by wschrabi » Tue Jul 22, 2008 1:47 pm
thank you, but what would you charge me, if you could program or adapt the source code to satisfy my problem? I have not the knowledge as you have, but I think you understand my demand. If you would add this wish to the furture realease of TeeChart, how long will it take to be released?
thanks anyway for your fast response.
walter
wschrabi
please give me a screenshot
Post by wschrabi » Tue Jul 22, 2008 2:13 pm
Dear Narcis,
could you give me a screenshoot of your code when beeing plotted?
It would be easier for me to imagine the results.
Tks
Wschrabi
