onmouseleaveseries event bug?
hantom
Post by hantom » Mon May 05, 2008 8:59 am
hi experts,
Onmouseleaveseries event occurs when moving cursor over one barseries
and just a few wide bar visible.
Is it a bug?
env:
XP SP2
VFP SP1
Tamás Handari
the sample code:
Acti Scree
Clea
oparent=Createobject('parentwindow')
With oparent
.AddObject('chart','olechart')
With .chart
.addseries(1)&&barseries
With .series(0)
.Add(2,'first',255)
.Add(1,'second',255)
.Add(3,'third',255)
.Add(2,'fourth',255)
.Add(3,'fifth',255)
.Add(3,'sixth',255)
.Marks.Visible=.F.
With .asBar
.BarWidthPercent=100
.OffsetPercent=0
.multibar=0
Endwith
Endwith
With .axis.Bottom
.Automatic=.F.
.Automaticminimum= .F.
.Automaticmaximum= .F.
.maximum=6
.minimum=1
.labels.Separation=1
.minortickcount=0
Endwith
.Aspect.View3D=.F.
.Visible=.T.
Endwith
.AddObject('lbl','label')
With .lbl
.Left=210
.Width=250
.Height=90
.FontSize=12
.WordWrap=.T.
.Caption='1: move mouse over the series horizontally'+Chr(13)+Chr(10)+;
'2: onmouseleaveseries() event occurs when move from one bar to another'
.Visible=.T.
Endwith
.Show
Endwith
Read Events
Return
***class
Define Class parentwindow As Form
Left=200
Width=600
Height=500
AllowOutput=.F.
Proc Unload
Clea Events
Endproc
Enddefine
Define Class olechart As OleControl
OleClass='TeeChart.TChart.8'
Width=600
Height=360
Top=140
Proc onmouseleaveseries
Lparameters seriesindex
?'onmouseleaveseries event'
Wait ' onmouseleaveseries event ' Window At 3,20 Timeout .6
Endproc
Enddefine
Post by Narcís » Mon May 05, 2008 9:59 am
Hi Tamás,
I'm not able to reproduce the problem here using TeeChart Pro v8.0.0.3 ActiveX and the code below. Could you please modify the code or send us a simple example project we can run "as-is" to reproduce the problem here and let us know the TeeChart version you are using?
Private Sub Form_Load()
    TeeCommander1.Chart = TChart1
    With TChart1
       .AddSeries scBar
        With .Series(0)
            .Add 2, "first", 255
            .Add 1, "second", 255
            .Add 3, "third", 255
            .Add 2, "fourth", 255
            .Add 3, "fifth", 255
            .Add 3, "sixth", 255
            .Marks.Visible = False
            With .asBar
                .BarWidthPercent = 100
                .OffsetPercent = 0
                .MultiBar = 0
            End With
        End With
        With .Axis.Bottom
            .Automatic = False
            .AutomaticMinimum = False
            .AutomaticMaximum = False
            .Maximum = 6
            .Minimum = 1
            .Labels.Separation = 1
            .MinorTickCount = 0
        End With
        .Aspect.View3D = False
        .Visible = True
    End With
Private Sub TChart1_OnMouseEnterSeries(ByVal SeriesIndex As Long)
    Caption = "Mouse entered series"
Private Sub TChart1_OnMouseLeaveSeries(ByVal SeriesIndex As Long)
    Caption = "Mouse left series"
hantom
Post by hantom » Mon May 05, 2008 10:14 am
Hi Narcís,
The sample code is written in visual foxpro 9.0.
Can You test in visual foxpro 9.0 environment?
If so, just copy the sample code below in a foxpro .prg file and run it.
I think one thing missed from your VB code:
it is important, that bars have to be wide
hantom
Post by hantom » Mon May 05, 2008 10:19 am
I bought ocx two weeks ago
8.0.0.3
Post by Yeray » Mon May 05, 2008 11:11 am
Excuse us, we haven't understood your problem. Now we reproduced the issue here and added it to the wish list to be fixed in further releases (TV52013029). It seems that when you have a bar series with BarwidthPercent at 100, and bottom axis minimum and maximum different from their defaults, MouseEnter and MouseLeave events don't work as expected.
hantom
Post by hantom » Mon May 05, 2008 11:37 am
Yeray,
the same problem with paging:
when bar series with BarwidthPercent at 100, and bottom axis minimum and maximum different from their defaults,
paging does not work nor with code, nor with PageNavigator object
test it please ! (or I can send you a test foxpro prg)
Tamás Handari
