Wrong Self-stacked Bar?
ESRI
Post by ESRI » Fri Mar 28, 2008 11:33 pm
I'm comparing Self-stacked Bar in TeeChartv7FeatureDemo.exe (Chart Styles->Standard->Bar) for 7006 and 7014. In 7006 for 3 series there is 3 separate bars. For 7014 there is 1 bar with some weird 3D twist. The "twist" can change... If I turn off 3D, in 7006 there is still 3 bars, in 7014 still one and sometimes the bar does not fit vertically, showing not all data.
Alex.
Post by Narcís » Mon Mar 31, 2008 9:24 am
Hi Alex,
I'm not able to reproduce this using v7.0.1.4. Could you please check this is the version you are using?
ESRI
Post by ESRI » Mon Mar 31, 2008 5:16 pm
But do you see "In 7006 for 3 series there is 3 separate bars. For 7014 there is 1 bar <consisting of 3 series>"?
Alex
Post by Yeray » Tue Apr 01, 2008 8:00 am
Hi Alex,
We've tested both v7.0.1.4 and v7.0.0.6 and we could see no difference between them. Note that we have one series with three points, not three series with one point. And setting MultiBar to mbSelfStack, we force the bar series to draw one point above the other. Also note that in this demo there's a checkbox that change MultiBar from mbSelfStack to mbNone and reverse.
ESRI
Post by ESRI » Tue Apr 01, 2008 6:48 pm
I think we are talking about different things :)
I've uploaded 4 images : bar_selfstacked_3D_7006.JPG, bar_selfstacked_2D_7006.JPG, bar_selfstacked_3D_7014.JPG, bar_selfstacked_2D_7014.JPG
Please have a look!
Alex.
Post by Yeray » Wed Apr 02, 2008 8:29 am
Hi Alex,
Now we understood what demo were you looking at and we could see the bug. I've added it to the wish list (TV52012936) to be fixed in further releases.
