Please back SnapStyle property to TChartTool v.7.12 and high
GAN
Post by GAN » Fri Feb 29, 2008 10:16 am
In TeeChart Pro 7.07 version for C++Builder6
Cursor tool has property TSnapStyle:SnapStyle
ChartTool1->SnapStyle = ssVertical;
There is no such property in the version of a component for C++Builder2007
(TeeChart Pro v.7.12 Win32).
Without this property the cursor is drawn not on a series line.
Please back this property for version of a component for C++Builder2007 or fix this problem.
To Narcís: In my previous topic (21 Feb 2008 08:22 Cursor tool have't snap style... )
i have made a typing error. I have written "Style: TCursorToolStyle" though wished to write "SnapStyle: TSnapStyle". I ask to excuse.
Post by Pep » Tue Mar 04, 2008 11:51 am
Hi GAN,
yes, using this property in C++2007 there's an ambiguity with the 'Stdctrls::ssVertical'.
I've added this issue on our bug/wish to modify it for the next releases. In meantime a solution is to assign it by using :
ChartTool1->SnapStyle = TSnapStyle(2);  // for Vertical..
GAN
Post by GAN » Thu Mar 06, 2008 7:03 am
Hi Pep,
Please, look into TeeTools.hpp (from TeeChart Pro v.7.12 Win32 C++Builder2007)
There is no SnapStyle property.
Compiler message: 'SnapStyle' is not a member of 'TCursorTool'!
Cut from TeeTools.hpp (from TeeChart Pro v.7.12 Win32 C++Builder2007 ):
class PASCALIMPLEMENTATION TCursorTool : public Teengine::TTeeCustomToolSeries
	typedef Teengine::TTeeCustomToolSeries inherited;
private:
protected:
public:
__published:
	__property Active  = {default=1};
	__property int ClickTolerance = {read=FClick, write=FClick, default=3};
	__property bool FollowMouse = {read=FFollowMouse, write=FFollowMouse, default=0};
	__property Pen ;
	__property Series ;
	__property bool Snap = {read=FSnap, write=FSnap, default=0};
	__property TCursorToolStyle Style = {read=FStyle, write=SetStyle, default=2};
	__property bool UseSeriesZ = {read=FUseSeriesZ, write=SetUseSeriesZ, default=0};
	__property TCursorToolChangeEvent OnChange = {read=FOnChange, write=FOnChange};
	__property TCursorToolChangeEvent OnSnapChange = {read=FOnSnapChange, write=FOnSnapChange};
public:
	#pragma option push -w-inl
	/* TCustomChartElement.Destroy */ inline __fastcall virtual ~TCursorTool(void) { }
	#pragma option pop
Cut from TeeTools.hpp (from TeeChart Pro v.7.07 Win32 C++Builder6):
private:
TSnapStyle FSnapStyle;
protected:
public:
__published:
	__property Pen ;
	__property Series ;
	__property TSnapStyle SnapStyle = {read=FSnapStyle, write=FSnapStyle, default=0};
public:
	#pragma option pop
Post by Narcís » Thu Mar 06, 2008 11:33 am
Hi GAN,
As you can see here, SnapStyle property was implemented for TeeChart Pro v8 VCL.
We have also checked that neither v7.07 for C++ Builder 6 nor v7.12 for C++ Builder 6 and 2007 have this property on their TeeTools.hpp.
Could it be possible that you used an evaluation version of v8 and their hpp replaced v7's?
GAN
Post by GAN » Fri Mar 07, 2008 10:47 am
Hi Narchs!
No, i'm not using an evaluation version of v8.
v7.07 for BCB 6 has SnapStyle. And this is the last version with SnapStyle for BCB6.
v7.07 for BCB 2007 and any other has not SnapStyle.
Tell me please, have you any plans to add this property to v7 Pro?
Or i need to buy v8 Pro?
Post by Narcís » Fri Mar 07, 2008 11:13 am
Hi GAN,
I've checked revisions of v7 and v8 source code and I can confirm that SnapStyle was implemented in v8.
Could you please post the installer where you say this property appears to a place where we can download it and send us its URL at info at steema dot com?
GAN
Post by GAN » Tue Mar 25, 2008 7:38 am
Hi Narchs!
You can download it from
http:\\www.diatehnn.ru\files\TeeChart7.07Builder6.exe
GAN
Post by GAN » Tue Mar 25, 2008 7:59 am
And you can see a little screen shot
[img]http:\\www.diatehnn.ru\files\SnapStyle.JPG[/img]
Post by Narcís » Wed Mar 26, 2008 11:31 am
Hi GAN,
Thanks for the information. We have added SnapStyle property in our v7 sources. I'll send you necessary files. You can use TeeRecompile tool for compiling and installing them on your IDE.
GAN
Post by GAN » Thu Mar 27, 2008 2:15 pm
Hi Narcis, biggest thanks! The problem with cursor snap style is resolved.
But there is another one. In v7.12 for BCB 2007 and BCB6 center of cursor (crosshair) draws not on a series line.
It was before update of my installation and still after.
You can download example (source and executable) of this problem from
http:\\www.diatehnn.ru\files\CursorTest.zip
Post by Narcís » Thu Mar 27, 2008 3:43 pm
Hi GAN,
You're welcome. I'm glad to hear that.
This is because the chart is in 3D. Cursor is plotted at Z=0 coordinate while series doesn't have 3D dimensions as it is a TFastLineSeries. You have 2 options to solve this:
1. Set chart to 2D:
	Chart1->View3D = false;
2. Change the TFastLineSeries to a TLineSeries.
GAN
Post by GAN » Fri Mar 28, 2008 10:23 am
Yes, you are right!
Thanks!
ChainSmokinCoder
SnapStyle on 7.12
Post by ChainSmokinCoder » Mon Apr 06, 2009 12:41 am
narcis wrote:Hi GAN,
Hi, I've been looking for this SnapStyle property and I couldn't find it in my TeeChart 7.12 ver.
I can see that it suppose to be in 7.07, but how come it doesn't exist in my 7.12?
I have search through TeeChart 7.12 Full source code in the TeeTools.pas and SnapStyle just isn't there.
Thank you.
Post by Narcís » Mon Apr 06, 2009 8:39 am
Hi ChainSmokinCoder,
I just sent you same files I sent to GAN.
ChainSmokinCoder
Customer download
Post by ChainSmokinCoder » Mon Apr 06, 2009 9:07 pm
I have received the files, much appreciated. However why aren't these put into TeeChart 7?
