how to change from bar to line or others
abing
Post by abing » Mon May 31, 2004 6:28 am
I use the teechart in a real-time system. per-second i put a data into a series. But later,i will chang the series' shape,for example from bar to line or to point.
how can i do it .
Thank you! Best Wishes!
Post by Pep » Mon May 31, 2004 8:17 am
not all the Series type can be changed dinamically. This depends on which type of values are stored in the Series. For example Arrow Series and Shape series, specifically, require values of type (X0,Y0) and (X1,Y1) whereas a BarJoin series only requires (X,Y) so this could not be changed. To change to a Series type which uses the same types of values you can do :
Private Sub Command1_Click()
  TChart1.ChangeSeriesType 0, scBar
Private Sub Form_Load()
With TChart1
    .AddSeries scLine
    .Series(0).FillSampleValues (10)
End With
abing
Post by abing » Mon May 31, 2004 11:41 am
This does well. Thank you very very much . 非常感谢!
