Color Grid Transparency property
Ideas and wishes for TeeChart
SteveP
Post by SteveP » Tue Mar 16, 2004 2:37 pm
Could a Transparency property be added to the ColorGrid so when there is more than one of them in 3D mode, they could be partially "see-through" and the color grids behind the front one show through. Similar to how a surface chart has transparency both to parts of its own surface behind its front portions or to other surface series.
windmaomao
Post by windmaomao » Thu May 27, 2004 8:12 pm
Exactly what I want too
StephanBonn
Re: Color Grid Transparency property
Post by StephanBonn » Mon Aug 31, 2009 1:33 pm
Hello together,
I am working with the 7.x version and I want to know if the current version has a transparency property for
the color grid series. This is a good reason to update.
Greetings
Stephan
Post by Narcís » Mon Aug 31, 2009 1:46 pm
Hi Stephan,
Yes, transparency for TColorGridSeries is implemented in TeeChart Pro v8 VCL. You may upgrade your v7 license here.
