Source code install error
dataview
Post by dataview » Mon Oct 01, 2007 4:01 pm
I'm using the TeeChart Recompile program (version 6.0.3.0) and am getting the following error when it trys to do the install:
TeeChart Installation
VERSION: 7
D2006.Win32 v10 (update 2) (BDS v4 Enterprise)
EXCEPTION:
File not found
It seems to work anyway, but I don't like errors.
Bill
Post by Narcís » Mon Oct 01, 2007 4:03 pm
Hi Bill,
Have you enabled any IDE checkbox you may not have?
dataview
Post by dataview » Mon Oct 01, 2007 4:50 pm
The only checkbox that is checked is the "Install packages into IDE's (VCL versions)" one.
Bill
Post by Narcís » Tue Oct 02, 2007 7:43 am
Hi Bill,
I'd like to apologise if I didn't explain myself correctly but I meant the checkboxes that appear at the left next to each IDE in the IDE list. The error seems to indicate that you tried to install TeeChart in an IDE you don't have installed on your machine.
dataview
Post by dataview » Tue Nov 06, 2007 3:55 pm
I see one installed enviornmebt listed, which looks like what I have installed, and it is checked.
Post by Narcís » Wed Nov 07, 2007 9:00 am
Hi Bill,
Thanks for the information. Yours seems to be quite an old TeeRecompile version. I've sent you a newer TeeRecompile version for TeeChart v7. Are you using TeeChart Pro v7.12 available at the client area? You could also try if this version works fine at your end.
dataview
Post by dataview » Wed Nov 07, 2007 2:19 pm
I am using version 7.12, but my TeeCompile version is 6.0.3.0.
Would you please resend me the latest version of TeeCompile. I had a typo in my e-mail address, and didn't get it.
Bill
Post by Narcís » Wed Nov 07, 2007 2:32 pm
Hi Bill,
Sure! Just done it.
BTW: I've noticed the difference in the e-mail address but didn't receive any error message e-mail.
dataview
Post by dataview » Wed Nov 07, 2007 4:19 pm
Unfortunately, my company blocks attachments like that.
Can I download the TeeCompile from somewhere on your site?
Bill
Post by Narcís » Thu Nov 08, 2007 10:21 am
Hi Bill,
Ok, I've uploaded it at our website. I've sent you an e-mail with the URL to download it.
dataview
Post by dataview » Thu Nov 08, 2007 1:43 pm
I downloaded the "new" version of TeeCompile, but it is actually version 6.0.3.0, the same as what I had.
Here is the output, that I probably should have included in my original posting.
Bill
Compilation started: 11/8/2007 8:39:09 AM
Tee710
Borland Delphi for Win32 compiler version 18.0
Copyright (c) 1983,2005 Borland Software Corporation
46552 lines, 0.48 seconds, 345032 bytes code, 3096 bytes data.
TeeUI710
37705 lines, 0.47 seconds, 218692 bytes code, 856 bytes data.
TeeDB710
5456 lines, 0.19 seconds, 43048 bytes code, 148 bytes data.
TeePro710
78193 lines, 1.38 seconds, 469208 bytes code, 3984 bytes data.
TeeGL710
11052 lines, 0.20 seconds, 69504 bytes code, 2944 bytes data.
TeeImage710
22985 lines, 0.31 seconds, 146820 bytes code, 11248 bytes data.
TeeLanguage710
58055 lines, 1.52 seconds, 1156020 bytes code, 2356 bytes data.
DclTeePro710
6349 lines, 0.53 seconds, 42644 bytes code, 284 bytes data.
DclTeeProStd710
6344 lines, 0.30 seconds, 38192 bytes code, 268 bytes data.
VERSION: 7
EXCEPTION:
File not found
EXCEPTION:
Operation aborted
Post by Pep » Fri Nov 09, 2007 11:52 am
do you have all the D2006 updates installed ?
dataview
Post by dataview » Fri Nov 09, 2007 2:22 pm
This is what I have:
Borland® Delphi® for Microsoft® Windows™ Version 10.0.2288.42451 Update 2 Copyright © 2005 Borland® Software Corporation. All Rights Reserved.
Post by Narcís » Mon Nov 19, 2007 11:31 am
Hi dataview,
In that case you could try installing the packages manually as described at Install.txt in C:\Program Files\Steema Software\TeeChart 8.01 for Delphi 2007\Delphi10.
dataview
Post by dataview » Mon Nov 19, 2007 2:05 pm
Thanks, but that is not necessary. As I wrote in my original posting, it works, even though I get the error message.
Bill
