Transparency is not correctly exported to some formats
Jeff
Post by Jeff » Mon Sep 24, 2007 11:39 pm
Dear support:
I noticed that transparent color is not correctly exported to some image formats, such as PDF, EPS, HTM, and GIF (which I assume is due to the number of colors supported by GIF format). Any fixes?
Jeff
Post by Narcís » Tue Sep 25, 2007 9:13 am
Hi Jeff,
Yes, that's right, transparency exporting is not supported. I've added your request to our wish-list to be considered for inclusion for future releases.
drrms
Re: Transparency is not correctly exported to some formats
Post by drrms » Wed Jun 16, 2010 5:00 pm
Hello.
This issue has been pending now for nearly 3 years. Can it PLEASE be addressed?
Longingly,
Richard.
Post by Sandra » Thu Jun 17, 2010 10:49 am
Hello Richard,
I have tested your bug and I confirm that when you export image as GIF format, now works fine using last version of TeeChart .Net.
Moreover, I have increased and modified feature request (TF02012471), and we try to solve problem of other formats (PDF,HTM,EPS) to be considered for inclusion in future releases
drrms
Post by drrms » Tue Jul 20, 2010 12:03 pm
Has there been any progress on this issue?
Post by Sandra » Tue Jul 20, 2010 12:16 pm
Hello drrms,
I am sorry, not yet
Richard
Post by Richard » Tue Jul 20, 2010 2:26 pm
Sandra wrote:Hello Richard,
Hello.
We have tried the latest TeeChart version and made simple project, that exports chart with transparent background to different formats. All formats, including GIF still comes with black background, instead of transparent. Project archive and gif example in the attach.
SteemaTestProject.rar
Sample project
(24.14 KiB) Downloaded 805 times
Post by Sandra » Wed Jul 21, 2010 12:23 pm
Hello Richard,
I tested your project, and I foun that changing next line of code:
TChart.Panel.Color = Color.Transparent;
for it line:
TChart.Panel.Transparent = true;
And adding in ExportButton it:
private void ExportButton_Click(object sender, EventArgs e)
            Steema.TeeChart.Drawing.BufferStyle buffer = TChart.Graphics3D.BufferStyle;
            TChart.Graphics3D.BufferStyle = Steema.TeeChart.Drawing.BufferStyle.None;
			switch (ComboBox.SelectedIndex)
				case 0:
					Export(new BitmapFormat(TChart.Chart));
					break;
				case 1:
					Export(new GIFFormat(TChart.Chart));
					break;
				case 2:
					Export(new JPEGFormat(TChart.Chart));
					break;
				case 3:
					Export(new PNGFormat(TChart.Chart));
					break;
            TChart.Graphics3D.BufferStyle = buffer;
Background color seems its transparent now. Could you please, check if you are changing first line of code for second line, works fine for you?
Richard
Post by Richard » Thu Dec 30, 2010 3:18 pm
Hi.
We have trued suggested solution. Attached archive contains four different outputs. The result is different from what was expected. Bmp, gif, jpg does not present transparency at all. Png gives transparency but renders text using some different font.
export.rar
Four export results
(117.61 KiB) Downloaded 823 times
Post by Sandra » Thu Dec 30, 2010 4:30 pm
Hello Richard,
I could check your problems with exporting and I have added these in bug list report with number [TF02015339]. We will try to fix it for next maintenance releases of TeeChart.Net.
