Custom vertical axis and LabelsSize
fabnav
Post by fabnav » Mon Apr 30, 2007 7:21 pm
I am finding that I can't get LabelsSize to work properly when using only custom axes.
For example, if you want to have three left axes, do you have to use the built-in left axis and then create two additional custom left axes?
I was trying to create three custom left axis and only use them, and it didn't work very well.
Bill
Post by Yeray » Thu May 03, 2007 8:44 am
Hi Bill,
I've made a project for a customer who requested something similar to you. Here's the code:
var i: Integer;
const nSeries = 6;
  ComboBox1.Items.Clear;
  ComboBox2.Items.Clear;
  for i := 0 to nSeries-1 do
    Chart1.AddSeries(TLineSeries);
    Chart1.CustomAxes.Add;
    Chart1[i].CustomVertAxis := Chart1.CustomAxes.Items[i];
    Chart1.CustomAxes.Items[i].Axis.Color := Chart1[i].Color;
    Chart1.CustomAxes.Items[i].Grid.Visible := False;
    ComboBox2.Items.Add('Series' + inttostr(i + 1));
    Chart1[i].FillSampleValues(20000);
    Chart1.CustomAxes.Items[i].PositionUnits := muPixels;
    if ((i+1) mod 2 = 0) then
      Chart1.CustomAxes.Items[i].OtherSide := True;
  Chart1.MarginUnits := muPixels;
  ComboBox1.Items.Add('20000');
  ComboBox1.Items.Add('5000');
  ComboBox1.Items.Add('500');
  ComboBox1.Items.Add('50');
  ComboBox1.ItemIndex := 0;
  ComboBox2.ItemIndex := 0;
  CheckBox1.Checked := True;
  CheckBox2.Checked := Chart1.CustomAxes.Items[0].OtherSide;
  Chart1.Draw;
  PlaceAxes();
procedure TForm1.PlaceAxes(nSeries: Integer=0; NextXLeft: Integer=0; NextXRight: Integer=0; MargLeft: Integer=0; MargRight: Integer=0);
const extraPos = 12;
const extraMargin = 45;
  if Chart1[nSeries].Active then
    if Chart1.CustomAxes.Items[nSeries].OtherSide then
      Chart1.CustomAxes.Items[nSeries].PositionPercent := NextXRight;
      NextXRight := NextXRight - Chart1.CustomAxes.Items[nSeries].MaxLabelsWidth - Chart1.CustomAxes.Items[nSeries].TickLength - extraPos;
      MargRight := MargRight + extraMargin;
    end
      Chart1.CustomAxes.Items[nSeries].PositionPercent := NextXLeft;
      NextXLeft := NextXLeft - Chart1.CustomAxes.Items[nSeries].MaxLabelsWidth - Chart1.CustomAxes.Items[nSeries].TickLength - extraPos;
      MargLeft := MargLeft + extraMargin;
  Chart1.MarginLeft := MargLeft;
  Chart1.MarginRight := MargRight;
  nSeries := nSeries + 1;
  if nSeries <= Chart1.SeriesCount - 1 then
    PlaceAxes(nSeries, NextXLeft, NextXRight, MargLeft, MargRight);
procedure TForm1.CheckBox1Click(Sender: TObject);
  Chart1[ComboBox2.ItemIndex].Active := CheckBox1.Checked;
  PlaceAxes();
procedure TForm1.CheckBox2Click(Sender: TObject);
  Chart1.CustomAxes.Items[ComboBox2.ItemIndex].OtherSide := CheckBox2.Checked;
  PlaceAxes();
procedure TForm1.ComboBox2Change(Sender: TObject);
  CheckBox1.Checked := Chart1[ComboBox2.ItemIndex].Active;
  CheckBox2.Checked := Chart1.CustomAxes.Items[ComboBox2.ItemIndex].OtherSide;
var i: Integer;
  for i := 0 to Chart1.SeriesCount-1 do
    Chart1[i].FillSampleValues(strtoint(ComboBox1.Text));
  PlaceAxes();
procedure TForm1.Button2Click(Sender: TObject);
  Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].PositionUnits := muPixels;
  Chart1[Chart1.SeriesCount-1].CustomVertAxis := Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1];
  if (Chart1.CustomAxes.Count mod 2 = 0) then
      Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].OtherSide := True;
  Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].Axis.Color := Chart1[Chart1.SeriesCount-1].Color;
  Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].Grid.Visible := False;
  ComboBox2.Items.Add('Series' + inttostr(Chart1.SeriesCount));
  ComboBox2.ItemIndex := ComboBox2.Items.Count-1;
  Chart1[Chart1.SeriesCount-1].FillSampleValues(Chart1[0].XValues.Count);
  PlaceAxes();
Probably this is more than what you need because in this there are axis in the other side (right), but I hope it will help you to see what you need.
I will try to explain in a few words what is this code doing:
-Create: This adds a predefined number of LineSeries (nSeries=6) to the chart, creates and assign a custom axis to each one of them and populate them. (Note that I'm not using the predefined Left Axis). Also is important to note that I change MarginUnits and all CustomAxis.PositionUnits to pixels to calculate them easier.
-PlaceAxes: Is a recursive method that calculates the position of all the Axes taking in consideration the MaxLabelsWidth and the TickLength of the already drawn axes.
-CheckBox1: Actives/ deactivates the Series shown at ComboBox2 (and its axis).
-CheckBox2: Changes the side of the CustomAxis of the Series shown at ComboBox2.
-Button1: Executes a FillSampleValues with a number of data indicated at ComboBox1.
-Button2: Adds a new LineSeries and its new CustomAxis to the chart.
I hope the explanation helps...
Post by Yeray » Thu May 03, 2007 9:00 am
Please, add this 3 lines to the TForm1.FormCreate to see the chart better.
Chart1.View3D := false;
Chart1.Title.Visible := false;
Chart1.Legend.Alignment := laBottom;
fabnav
Post by fabnav » Thu May 03, 2007 1:50 pm
Hi Veray,
Thank you for the code. I ran it and it isn't what I'm looking for.
1. I don't think it works when there are multiple series per custom axis.
2. If you add the following code into your series create loop:
Chart1.CustomAxes.Items.Title.Caption := 'Caption ' + IntToStr(i);
Chart1.CustomAxes.Items.Title.Angle := 90;
you will see that the axis captions are overwritten.
3. I am using StartPosition and EndPosition to place the axes in a line vertically. I am allowing for four pairs of left and right axis, as indicated below (with the chart in the middle of my diagram).
Bill
Post by Yeray » Fri May 04, 2007 9:35 am
Hi Bill,
1) The code above was thought for having one Custom Axis per Series and avoid overlapping.
2) If you want to add a title to each Custom Axis you should increment the axis separation setting higher extraPos and extraMargin (at PlaceAxes method). Following values work for me: extraPos := 32 and extraMargin := 62
3) You should assign a left and a right custom axis to each of your series but it is not possible at this moment. But, as a workaround, you can create two series with the same values and assign a left custom axis to one and a right custom axis to the other. This would be as follows:
var i: Integer;
  for i := 0 to 3 do
    Chart1[Chart1.SeriesCount-1].FillSampleValues(2000);
    Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].StartPosition := i * 25;
    Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].EndPosition := (i+1) * 25;
    Chart1.AddSeries(CloneChartSeries(Chart1[Chart1.SeriesCount-1]));
    Chart1.CustomAxes.Items[Chart1.CustomAxes.Count-1].OtherSide := true;
  Chart1.Legend.Visible := false;
  Chart1.MarginLeft := 7;
  Chart1.MarginRight := 7;
