the problem background window is printed whenever operating
kinghyun
Post by kinghyun » Wed Apr 25, 2007 5:21 am
HI―^^/~*
When I pop up several pages with Teachart program
I usually see background screen on which Teechart program should be displayed.
As if it has a great hole on it..
Is this a kind of bug in Teechart?
though I can see the right page with the click on 'Refresh'
the problem is that I come across the Backroud screen again with another
new chart and I see the chart with error which was opened once on the screen.
How can I solve it in this case?
Post by Narcís » Wed Apr 25, 2007 10:53 am
Hi kinghyun,
Which TeeChart version are you using? Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
kinghyun
Thank you for your quick reply^^
Post by kinghyun » Wed May 02, 2007 4:41 pm
Haven't you ever went through this case?
Checking the sources used in my company, I can easily find these cases.
If I explain in detail, my point is 'Pop-up window' and 'Considerable Series'.
The case in which windows with the T-chart have holes on the screen takes place in random.
I think that occurs more common in out-dated computers with many pop-ups on the screen.
That computer has 2.80GB CPU and 1GB RAM.
It hardly occurs in the computers with better than 3GB CPU and 2GB RAM.
720 data are put in the X-axis and sometimes more than 4320 data can be put.
The problem is that it happens so randomly that it is hard to find the cause.
I usually use the source like this in general.
	Option Explicit
'	Response.Clear
	Response.Buffer = True
	Response.Expires = 0
'	response.expires = -1
'	Response.ExpiresAbsolute = Now() - 1
	Response.AddHeader "Cache-Control", "private"
	Response.AddHeader "pragma", "no-cache"
	Response.CacheControl = "no-cache"
<!-- #include virtual = "/inc/totalpage/inc_all_page.asp" -->
<!-- #include virtual = "/inc/database/inc_DAL_Helpers.asp" -->
<OBJECT RUNAT=server PROGID=DAL.DAOSimple id=oDAOSimple> </OBJECT>
<!-- #include virtual = "/inc/product/os390/function_sub_systemid.asp" -->
<!-- #include virtual = "/inc/product/os390/com_function_date.asp" -->
<!-- #include virtual = "/inc/proc/com_function_number.asp" -->
	Dim m_modName
	Dim blnDebug, blnResponseEnd
	m_modName		= "online/04.asp"
	blnDebug		= false
	blnResponseEnd  = false
	dim strSystem, strTime
	dim avg_time
Function GetBySystem()
		GetBySystem = _
			oDAOSimple.RunSPReturnString("usp_os390_common_getbysystemid", , _
				Application("Conn_String"))
end Function
Call Page_Load()
<SCRIPT LANGUAGE=javascript>
function window_onload()
	ifrm.document.location.href = "04_ifrm.asp?lstSystem=<%=strSystem%>&lstTime=<%=strTime%>";
	TChartInit();
	NowDateTime();
	SetSelect(frmForm1.lstSystem,"<%=strSystem%>");
	SetSelect(frmForm1.lstTime,"<%=strTime%>");
	setTimeout ("Move2()",2*60*1000)
function Move(strValue)
	setTimeout ("Move()",5*60*1000)
function Move2()
	frmForm1.action = "04.asp";
	frmForm1.method = "Post";
	frmForm1.submit();
function NowDateTime()
	dNowDateTime.innerHTML = GetNowDate(".","F") + "(" + GetWeekDay("K") + ") " + GetNowTime("").substring(0,5);
	setTimeout("NowDateTime();",60000);
function MM_reloadPage(init)
	if (init==true) with (navigator)
		if((appName=="Netscape")&&(parseInt(appVersion)==4))
			document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage;
	else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
MM_reloadPage(true);
</script>
<script ID="clientEventHandlersVBS" LANGUAGE="vbscript">
	Sub TChartList()
	Sub TChartInit()
		frmForm1.TChart1.Environment.IEPrintWithPage = true
		frmForm1.TChart1.Import.LoadFromURL("<%=gUrlMain%>" & "os390/tchart_tee/online_cpu_01.tee")
		frmForm1.TChart1.RemoveAllSeries
		<%call View_011()%>
	Sub TChart1_OnClick()
	Sub TChart1_OnClickSeries(SeriesIndex, ValueIndex, Button, Shift, X, Y)
		msgBox "Time : " + CStr(frmForm1.TChart1.Series(SeriesIndex).PointLabel(ValueIndex)) + chr(10) + frmForm1.TChart1.Series(SeriesIndex).Title & " Value : "+CStr(frmForm1.TChart1.Series(SeriesIndex).PointValue(ValueIndex))
		frmForm1.TChart1.StopMouse
	sub button1_onclick()
		frmForm1.TChart1.ShowEditor
	end sub
</script>
<style>
body{filter='progid:DXImageTransform.Microsoft.Gradient(GradientType=0, StartColorStr=pink, EndColorStr=#FFFFFF)'}
.test1 {filter='progid:DXImageTransform.Microsoft.Gradient(GradientType=0, StartColorStr=#EEFCFF, EndColorStr=#94CBD9)'}
</style>
</head>
<body bgcolor="#DEF6FF" leftmargin="0" topmargin="0" marginwidth="0" marginheight="0" onload="return window_onload()">
<form name="frmForm1">
<table width="100%" height="100%" border="0" cellpadding="0" cellspacing="0">
<!-- Teechart -->
<tr>
	<td height="85%" colspan="2">
	<table width="100%" height="100%" border="0" cellpadding="0" cellspacing="2">
<OBJECT classid="CLSID:B6C10489-FB89-11D4-93C9-006008A7EED4" 					data=data:application/x-oleobject;base64,iQTBton71BGTyQBgCKfu1FRQRjALVENoYXJ0Q2hhcnQABExlZnQCAANUb3					ACAAVXaWR0aAMCAwZIZWlnaHQD1gEUQmFja1dhbGwuQnJ1c2guQ29sb3IHB2NsV2hpdGUUQmFja1dhbGwuQnJ1c2guU3R5bGUHB					2JzQ2xlYXISR3JhZGllbnQuRGlyZWN0aW9uBwtnZEJvdHRvbVRvcBFHcmFkaWVudC5FbmRDb2xvcgcHY2xXaGl0ZRRMZWZ0V2Fs					bC5CcnVzaC5Db2xvcgcHY2xXaGl0ZQ5MZWZ0V2FsbC5Db2xvcgcHY2xXaGl0ZQxNYXJnaW5Cb3R0b20CAwlNYXJnaW5Ub3ACBRJ					UaXRsZS5Gb250LkNoYXJzZXQHD0hBTkdFVUxfQ0hBUlNFVBFUaXRsZS5Gb250LkhlaWdodALtD1RpdGxlLkZvbnQuTmFtZQYEsb					y4shBUaXRsZS5Gb250LlN0eWxlCwZmc0JvbGQAElRpdGxlLlRleHQuU3RyaW5ncwEGASAAFUJvdHRvbUF4aXMuQXhpcy5XaWR0a					AIBF0JvdHRvbUF4aXMuR3JpZC5WaXNpYmxlCBtCb3R0b21BeGlzLkxhYmVsc1NlcGFyYXRpb24CABlCb3R0b21BeGlzLk1pbm9y					VGlja0NvdW50AgQdQm90dG9tQXhpcy5UaXRsZS5Gb250LkNoYXJzZXQHD0hBTkdFVUxfQ0hBUlNFVBtCb3R0b21BeGlzLlRpdGx					lLkZvbnQuQ29sb3IHBmNsQmx1ZRxCb3R0b21BeGlzLlRpdGxlLkZvbnQuSGVpZ2h0AvMaQm90dG9tQXhpcy5UaXRsZS5Gb250Lk					5hbWUGBLG8uLIOQ2hhcnQzRFBlcmNlbnQCBRJMZWZ0QXhpcy5BdXRvbWF0aWMIGUxlZnRBeGlzLkF1dG9tYXRpY01heGltdW0IG					UxlZnRBeGlzLkF1dG9tYXRpY01pbmltdW0IE0xlZnRBeGlzLkF4aXMuV2lkdGgCARBMZWZ0QXhpcy5NYXhpbXVtBQAAAAAAAADI					BUAXTGVmdEF4aXMuTWlub3JUaWNrQ291bnQCBBRMZWZ0QXhpcy5UaXRsZS5BbmdsZQMOARZMZWZ0QXhpcy5UaXRsZS5DYXB0aW9					uBgxDUFW757/rwLJbJV0bTGVmdEF4aXMuVGl0bGUuRm9udC5DaGFyc2V0Bw9IQU5HRVVMX0NIQVJTRVQZTGVmdEF4aXMuVGl0bG					UuRm9udC5Db2xvcgcGY2xCbHVlGkxlZnRBeGlzLlRpdGxlLkZvbnQuSGVpZ2h0AvEYTGVmdEF4aXMuVGl0bGUuRm9udC5OYW1lB					gVAsby4shJMZWZ0QXhpcy5UaXRsZVNpemUCARBMZWdlbmQuQWxpZ25tZW50BwhsYUJvdHRvbRFMZWdlbmQuQ29sb3JXaWR0aAIF					E0xlZ2VuZC5Gb250LkNoYXJzZXQHD0hBTkdFVUxfQ0hBUlNFVBJMZWdlbmQuRm9udC5IZWlnaHQC8xBMZWdlbmQuRm9udC5OYW1					lBgaxvLiyw7wSTGVnZW5kLkxlZ2VuZFN0eWxlBwhsc1NlcmllcxFMZWdlbmQuU2hhZG93U2l6ZQIAE0xlZ2VuZC5TeW1ib2wuV2					lkdGgCBRBMZWdlbmQuVGV4dFN0eWxlBwhsdHNQbGFpbg1MZWdlbmQuVG9wUG9zAgATUmlnaHRBeGlzLkF1dG9tYXRpYwgaUmlna					HRBeGlzLkF1dG9tYXRpY01heGltdW0IGlJpZ2h0QXhpcy5BdXRvbWF0aWNNaW5pbXVtCBRSaWdodEF4aXMuQXhpcy5XaWR0aAIB					FlJpZ2h0QXhpcy5HcmlkLlZpc2libGUIEVJpZ2h0QXhpcy5NYXhpbXVtBQAAAAAAAADIBUAYUmlnaHRBeGlzLk1pbm9yVGlja0N					vdW50AgQcUmlnaHRBeGlzLlRpdGxlLkZvbnQuQ2hhcnNldAcPSEFOR0VVTF9DSEFSU0VUG1JpZ2h0QXhpcy5UaXRsZS5Gb250Lk					hlaWdodALzGVJpZ2h0QXhpcy5UaXRsZS5Gb250Lk5hbWUGBrG8uLLDvBJUb3BBeGlzLkF4aXMuV2lkdGgCAQ9Ub3BBeGlzLlZpc					2libGUIBlZpZXczRAgNWm9vbS5BbmltYXRlZAkKQmV2ZWxPdXRlcgcGYnZOb25lCkJldmVsV2lkdGgCAAtCb3JkZXJTdHlsZQcI					YnNTaW5nbGUFQ29sb3IHB2NsV2hpdGUAAAAAAAACAAAAAP////8=
		height=500 id=TChart1 style="HEIGHT: 500; LEFT: 0px; TOP: 0px; WIDTH: 980px" type=application/x-oleobject
		width=980></OBJECT>
	</table>
	</td>
</tr>
</table>
<iframe name= "ifrm" style = "HEIGHT:500px; WIDTH: 500px;DISPLAY:none"></iframe>
</form>
</body>
</html>
	Sub Page_Load()
		strSystem		= rtrim(Request("lstSystem"))
		strTime			= rtrim(Request("lstTime"))
		if strSystem	= ""	or isnull(strSystem)		then
			strSystem = "HQ"
		end if
		if strTime	= ""	or isnull(strTime)		then
			strTime = "24hour"
		end if
		If IsFormValid = false Then
			Call ErrorMsg( _
					m1100, _
					m_modName)
			Response.End
		End If
		Call Init()
	Sub Init()
	if strTime = "24hour" then
		avg_time = 2
		avg_time = 10
	end if
	Function IsFormValid
		IsFormValid = true
		If Len(strSystem) = 0 Then
			IsFormValid = false
		End if
	End Function
sub View_011
	dim j,u,x
	dim Rs,Rs1
	dim Gr_011,Gr_012
	dim time_per_cnt
	dim job_group_cnt
		avg_time = 2
		time_per_cnt = (60 / avg_time ) * 24
		avg_time = 10
		time_per_cnt = ((60 / avg_time ) * 24) * 7
	end if
	set Rs=oDAOSimple.RunSPReturnRs("usp_os390_online_cpu_04",Array(_
						mp2(strSystem),mp2("ALL"),mp2(strTime)),_
	if Rs.EOF then
		Gr_011 = null
		Gr_011 = Rs.GetRows()
	end if
	Rs.Close()
	Set Rs = Nothing
	frmForm1.TChart1.Axis.Bottom.Title.Caption ="        Time "
	frmForm1.TChart1.Axis.Left.Maximum = 100
<%	if not isnull(Gr_011) then
		job_group_cnt =   (Ubound(Gr_011,2)+1) / time_per_cnt
		for u= 0 to job_group_cnt -1 	%>
			frmForm1.TChart1.AddSeries(3)
<%		next
		for j = 0 to  Ubound(Gr_011,2)
				x = left(Gr_011(0,j),2) & ":" & right(Gr_011(0,j),2)
				x = mid(Gr_011(0,j),5,2) & "/" & mid(Gr_011(0,j),7,2)& " " & mid(Gr_011(0,j),9,2)& ":" &mid(Gr_011(0,j),11,2)
			end if		%>
			frmForm1.TChart1.Series(<%=j mod job_group_cnt%>).asArea.AreaPen.Visible = false
			frmForm1.TChart1.Series(<%=j mod job_group_cnt%>).asArea.MultiArea = 1
			frmForm1.TChart1.Series(<%=j mod job_group_cnt%>).ShowInLegend = True
			frmForm1.TChart1.Series(<%=j mod job_group_cnt%>).Title = "<%=Gr_011(1,j)%>"
			frmForm1.TChart1.series(<%=j mod job_group_cnt%>).Add <%=Gr_011(2,j)%>,"<%=x%>",536870912
<%		next
		erase Gr_011
	end if
end sub
Post by Marc » Tue May 15, 2007 2:12 pm
We're not able to reproduce the problem here yet. There was a similar issue relating to multiple popup windows of Internet Explorer. Chart repaints were not correctly taking place across different browser windows.
Please check and disable the 'Show Window contents while dragging' option to confirm whether that changes behaviour. It is accessible via right mouseclick on 'My Computer' to get the properties menu, then Advanced tab, 'Performance'.
