Color Grid Transparency property
Could a Transparency property be added to the ColorGrid so when there is more than one of them in 3D mode, they could be partially "see-through" and the color grids behind the front one show through. Similar to how a surface chart has transparency both to parts of its own surface behind its front portions or to other surface series.
Re: Color Grid Transparency property
Hello together,
I am working with the 7.x version and I want to know if the current version has a transparency property for
the color grid series. This is a good reason to update.
Greetings
Stephan
Greetings
Stephan
Hi Stephan,
Yes, transparency for TColorGridSeries is implemented in TeeChart Pro v8 VCL. You may upgrade your v7 license here.
