Sorry guys, needing even more help.
I am plotting a graph for the period of the day. I want to be able to see the whole day plotted against the bottom even when I have only plotted the part of it.
When I manually plot the graph it all works when I uncheck the automatic scales and set the min and max value. However, when using a DBChart this does not work.
Any ideas?
DateTime Values
Hi, David.
As far as changing axis scales and doing it manually, TChart and TDBChart should work the same. Are your series XValues really true datetime values ? How do you define axis range (minimum and maximum value) ? Using the following code it works just fine:
With DBChart1.Axes.Bottom do
Automatic := False;
SetMinMax(yourstartdate,yourenddate);
// or SetMinMax(yourstartdate,yourstartdate+1.0); <- one day
end
Marjan Slatinek,
I had indeed done that in the past but thought it didn't work as the bars seemed to overlap each other and what I got was a jumbled mess. I have a stacked bar with 2 series using the same stack group.
When I changed the bar width to 10% for both bars it displayed fine but doesn't really help me understand why we get this overlapping issue.
