Hide line sections where X or Y value is Zero(0)in XY Chart
Faizullah Khan
Post by Faizullah Khan » Fri Jul 14, 2006 5:16 am
Is it possible that we hide the section of line where X or Y point value
is Zero (0) . kindly help me in this regard.
VB 6.0
TeeChart v7
Thanks & Regards
Post by Narcís » Fri Jul 14, 2006 7:38 am
Hi Faizullah,
You can try doing something like this:
Private Sub AddValue(X As Double, Y As Double)
    If ((X = 0) Or (Y = 0)) Then
        TChart1.Series(0).AddXY X, Y, "", clNone
    Else
        TChart1.Series(0).AddXY X, Y, "", clTeeColor
    End If
Private Sub Form_Load()
    TChart1.AddSeries scLine
    AddValue -2, 6
    AddValue -1, 2
    AddValue 0, 3
    AddValue 1, 5
    AddValue 2, 0
    AddValue 3, 8
    AddValue 4, 4
    AddValue 5, 0
    AddValue 6, 2
Faizullah Khan
Post by Faizullah Khan » Tue Aug 01, 2006 6:25 am
Thanks it works fine.
How we check the property of point e.g. At Run time We want to show
the point that is already marked as " clNone " or We want to assign "clNone" property to another point.
Thanks & Regards
Post by Pep » Tue Aug 01, 2006 9:00 am
you can use the PointColor property :
TChart1.Series(0).PointColor(Index) = clNone
Faizullah Khan
Post by Faizullah Khan » Wed Aug 02, 2006 7:40 am
Thanks for timely responce
This code works fine
Thanks & Regards
