ColorBandTool
Vivo
ColorBandTool
Post by Vivo » Tue Jun 27, 2006 9:18 pm
Am I correct in that the color band tool can not be used on a custom axis?
Also, can I put only a partial colorband up? or am I going to have to draw it using on after draw?
Adrian
Post by Narcís » Wed Jun 28, 2006 10:05 am
Hi Adrian,
No, color band tools can also be assigned custom axes, i.e.:
    With TChart1.Tools.Items(0).asColorband
        .Axis = TChart1.Axis.Custom(0)
        .StartValue = 100
        .EndValue = 200
    End With
I'm not sure of what are you exactly trying to get, can you please be more specific on what a "partial colorband up" consists? Do you mean a colorband not covering the full axis range?
Vivo
Post by Vivo » Wed Jun 28, 2006 1:39 pm
Yes. If attached to a vertical axis, have it only show up between x and x'. By default, I think the colour band will span the entire x axis, between y and y'. Is that correct?
Adrian
Post by Narcís » Wed Jun 28, 2006 2:04 pm
Hi Adrian,
This is not possible with a color band. However, you can achieve that using a rectangle tool and doing something like this:
Dim Go As Boolean
Private Sub Form_Load()
    For i = 0 To 100
        TChart1.Series(0).Add Rnd * 100, "", clTeeColor
    Next
    TChart1.Tools.Items(0).asRectangle.Shape.Transparency = 50
    Go = True
    If Go Then
        With TChart1.Tools.Items(0).asRectangle
            .Left = TChart1.Axis.Left.Position
            .Top = TChart1.Series(0).CalcYPosValue(50)
            .Height = TChart1.Series(0).CalcYPosValue(20) - .Top
            .Width = TChart1.Series(0).CalcXPosValue(40) - .Left
        End With
        Go = False
    End If
Private Sub TChart1_OnRectangleToolDragging()
    TChart1.Tools.Items(0).asRectangle.Left = TChart1.Axis.Left.Position
Private Sub TChart1_OnRectangleToolResizing()
Vivo
Post by Vivo » Wed Jun 28, 2006 6:24 pm
        .StartValue = 100
        .EndValue = 200
    End With
Uh, how is this done in MFC/C++?
I've tried the following without success:
		CAxis& axis = tchart.GetAxis().GetCustom(m_AxisIds[index]);
		CToolList & tools = tchart.GetTools();
		CColorBandTool & colourBand = tools.GetItems(m_ColourBand).GetAsColorband();
		COleVariant iDispatch;
		iDispatch.vt = VT_DISPATCH;
		iDispatch.pdispVal = axis.m_lpDispatch;
		colourBand.SetAxis(iDispatch.Detach());
How do I do this correctly?
There is no rectangle tool. I'm using TChart 7.0.0.3. And due to the tight schedule we have, I am not authorised to upgrade to the new version.
However, for reference, what compatibility issues are there if I were to upgrade to 7.0.0.8, and would I just do the Project->Add To Project->Components and Controls->TeeChart Pro Activex control v7 on the newly installed TChart to update the wrappers? Also, what other issues should I be aware of. What sort of testing regime do you do?
Adrian
Post by Narcís » Thu Jun 29, 2006 8:26 am
Hi Adrian,
Yes, you are right, rectangle tool wasn't defined. However we have recently fixed this as you can read in this message. Here you'll find the instructions to solve this and some code on how to use TeeChart tools in VC++ applications.
There won't be any compatibilty issues as we are specially concerned on keeping TeeChart being backward's compatible. To upgrade to v7.0.0.8, at least, you should unregister existing TeeChart7.ocx and register the new one. The easiest way is uninstalling existing one using the binary installer and install latest version. Also, you'll find v7 ActiveX version release notes here, so that you can check what is being changed in each release.
Vivo
Post by Vivo » Thu Jun 29, 2006 1:53 pm
Yeah, I saw that one, but I cannot easily use a CRectangle if that wrapper class does not exist. Would you be able to pass me the missing wrapper classes to me?
Adrian
Post by Narcís » Thu Jun 29, 2006 2:14 pm
Hi Adrian,
As told in the message I pointed, the classes are available at our attachments newsgroups. However, I've already sent them to your forums contact e-mail address.
Vivo
Post by Vivo » Thu Jun 29, 2006 2:16 pm
Hi Narcís,
Additionally, if I use tchart.GetTools().Add(tcRectangle) a First-chance exception is thrown (0xe06d7363). So I do not think this is going to work anyway.
Oh, and I have discovered that my email address is not correct. I've corrected it now. (Had an extra letter in there. :oops:)
I've also tried to use
	CTChart& tchart = GetTChart();
		CAxis & axis = tchart.GetAxis().GetCustom(m_AxisIds[index]);
		m_ColourBand = tools.Add(tcColorband);
		VARIANT iAxis;
		iAxis.vt = VT_DISPATCH;
		iAxis.pdispVal = axis;
		colourBand.SetAxis(iAxis);
as described in that other post but although it shows up, it does not move when I move that axis around.
Adrian
Post by Narcís » Thu Jun 29, 2006 2:21 pm
Hi Adrian,
Have you tried using the classes I've just sent you?
Vivo
Post by Vivo » Thu Jun 29, 2006 2:25 pm
Hi Narcís,
Sorry, I just edited my previous post. See there.
Adrian
Post by Narcís » Thu Jun 29, 2006 2:28 pm
Hi Adrian,
Ok, I've forwarded my previous e-mail to the corrected address. Can you please test if they work at your end?
Vivo
Post by Vivo » Thu Jun 29, 2006 2:30 pm
I didn't get any further than what I said in the prevous post:
Any ideas?
Adrian
Post by Narcís » Mon Jul 10, 2006 11:47 am
Hi Adrian,
Could you finally solve this issue using the files I sent?
Vivo
Post by Vivo » Tue Jul 11, 2006 5:59 pm
No, as I said before:
However, I was able to get the handle to the Device Context and was able to implement my own semi-transparent rectangle.
Adrian
