how can i change through the code
Aravind
Post by Aravind » Tue May 23, 2006 8:53 am
i want to change/set stacked property of the bar chart to either of the following
1.stacked
2.none
3. side stacked
i want to this through vb code
arav
Post by Narcís » Tue May 23, 2006 9:02 am
Hi arav,
1.stacked
    TChart1.Series(0).asBar.MultiBar = mbStacked
2.none
    TChart1.Series(0).asBar.MultiBar = mbNone
3. side stacked
    TChart1.Series(0).asBar.MultiBar = mbSide
Aravind
how can i bring all labels/values front (bring to front) on
Post by Aravind » Tue May 23, 2006 9:58 am
how can i bring all labels/values front (bring to front) on the chart
i am drawing various graphs such as line,bar,stackedbar, horizbar, in the bar chart the values hide behind the bar and not able to see...
how can i bring them forward and how can i set this property in through the code for the entire series or collection of series ..
aravind
Post by Narcís » Tue May 23, 2006 10:03 am
Hi Aravind,
I'm not able to reproduce the issue here. Could you please send us an example we can run "as-is" to reproduce the problem here?
You can post your files at news://www.steema.net/steema.public.attachments newsgroup.
Aravind
sorry this is not issue
Post by Aravind » Tue May 23, 2006 10:11 am
hi
when i draw the bar chart , some values hide behind the bar , i want to bring them front , so that i can see all values plotted ..
aravind
Aravind
i posted the tee file
Post by Aravind » Tue May 23, 2006 10:17 am
i posted the tee file newsgroup pls check it and advise me
aravind
Aravind
any info on my previous post
Post by Aravind » Wed May 24, 2006 9:05 am
need help asap
aravind
Post by Pep » Wed May 24, 2006 9:10 am
Hi Aravind,
Yes, this is by default for Stacked 2D Bar Series, we've on our wish list to be considered for further releases.
As a way arounds :
1) Use the DragMarks tool
2) Set a different arrow length for the Marks of each Series. (setting the ArrowLength to negative value).
3) Placing custom markers, for example using Annotation tools.
