Error Message
Bob
Error Message
Post by Bob » Tue Feb 10, 2004 1:03 am
When I delete a form in Borland, Sometimes TEE6C5.BPL throws a read access violation. Not always. The chart is just a simple bar chart. Should I be cleaning us something before I delete the form?
Bob.
Post by Pep » Tue Feb 10, 2004 10:03 am
Hi Bob,
difficult to know the problem. Have you tried to "Free" all teh series before to delete it ?
Bob
Post by Bob » Tue Feb 10, 2004 5:24 pm
Hi Pep,
No I haven't. The chart and series are already on the form when I create it. Do I need to free them before I delete the form?
Bob.
Marjan
Post by Marjan » Mon Feb 23, 2004 12:04 pm
8576887 wrote:Do I need to free them before I delete the form?
Normally no. I've tried to replicate the problem you're having here - but it worked just fine. Do you get the same error when you use runtime packages and when you build a single exe with no runtime packages ?
If there is not too much trouble, can you send me small application (sources only!) which demonstrates this problem ? I'll test it on my machine and try to determine, what's going on. You can send it to marjan at steema dot com email address.
Marjan Slatinek,
