Problem with Brother printer
Aligator
Post by Aligator » Sat Dec 03, 2005 11:52 am
I got a trouble when printing a chart on a Brother Laser Color HL-2700-CN, nothing is printed and the printer stays hooked with 'Autotest' on the display .... solution ? :shock: Teechart ActiveX V7 , win XP pro
:shock: Thanks
JP
Post by Narcís » Mon Dec 05, 2005 9:37 am
Hi JP,
Does it only happens when printing TeeChart on that printer? Does it also happens with other printers? Are you using the latest printer drivers available?
Aligator
Post by Aligator » Mon Dec 05, 2005 9:47 am
Hi, thanks for your answer.
Yes, there is no problem with the others printers from my app. The drivers are the last available... I don't get any problem from microsoft office, crystal report, Adobe ..;etc ... only from teechart. :shock:
There is probably a mistake in the init chain.. The printer hooks imediately.
This is a very new printer, I guess.
JP
Post by Pep » Fri Dec 09, 2005 11:29 am
this problem is most likely related to specific printer driver + operating system combination. I remember a customer who has similar problems, and I think he solved by using the PCL driver. You could try to use a different printer driver.
