Draggable Vertical Lines...
Maxc72
Post by Maxc72 » Fri Nov 25, 2005 12:59 pm
I must create horizontal-draggable vertical lines over a graph, moreover i must know what value them have over a serie..
Somebody could help me?
Reagards
Post by Narcís » Fri Nov 25, 2005 1:08 pm
Hi Maxc72,
I'd suggest you to use a TColorLineTool and implement something like the code below on its DragLine event.
procedure TForm1.ChartTool1DragLine(Sender: TColorLineTool);
  Chart1.Title.Text[0]:=FloatToStr(Sender.Value);
For more information on TChart tools features please have a look at TeeChart features demo available at its program group.
Maxc72
Post by Maxc72 » Fri Nov 25, 2005 5:37 pm
Hi thank's for your help, i've tried it and it works fine, but i need that the line height is adjustable and not fixed to the graph panel. i need that the line heigth is about half of the graph panel height..
Post by Narcís » Mon Nov 28, 2005 10:11 am
Hi Maxc72,
Then you can use a TColorBandTool and do something like:
var
  Form1: TForm1;
  StartVal, MidVal, EndVal: Double;
  ToolHeight: Integer;
implementation
{$R *.dfm}
  Series1.FillSampleValues();
  ToolHeight:=Chart1.Height div 2;
  MidVal:=(Series1.MaxYValue-Series1.MinYValue)/2;
  With ChartTool1 do
    StartValue:=MidVal - (ToolHeight div 2);
    EndValue:=MidVal + (ToolHeight div 2);
    StartLine.AllowDrag:=True;
    EndLine.AllowDrag:=True;
    StartVal:=StartValue;
    EndVal:=EndValue;
  Chart1.Title.Text[0]:=FloatToStr(MidVal);
  if ChartTool1.StartValue <> StartVal then
    ChartTool1.EndValue:=ChartTool1.StartValue+ToolHeight;
    StartVal:=ChartTool1.StartValue
  end
    if ChartTool1.EndValue <> EndVal then
      ChartTool1.StartValue:=ChartTool1.EndValue-ToolHeight;
      EndVal:=ChartTool1.EndValue;
  MidVal:=StartVal+(ToolHeight/2);
Maxc72
Post by Maxc72 » Mon Nov 28, 2005 12:00 pm
Hi I've tried to use the code but i obtain a very wide band, I've reduced the wide of the band but the heigth is still equal to graph panel and if i vertical scroll the graph the band is still here.
There is another problem, when i try to set dragging at runtime it have no effect, this code don't work at runtime:
ChartTool1.StartLine.AllowDrag:=True;
ChartTool1.EndLine.AllowDrag:=True;
if i create the tool in the ide and i set the dragging properties to true it work's fine and i can turn it on and off at runtime, but if i create the bar at runtime i can't set this properties (i.e. i can set them but there is no effect)
narcis wrote:Hi Maxc72,
var
  Form1: TForm1;
implementation
{$R *.dfm}
  With ChartTool1 do
    EndVal:=EndValue;
  end
Post by Narcís » Tue Nov 29, 2005 4:58 pm
Hi Maxc72,
Ok, then you can calculate it from TChart's rectangle (ChartRect property). Using the code below may work better for what you request.
var
  Form1: TForm1;
implementation
{$R *.dfm}
  MidVal:=Series1.MinYValue+(Series1.MaxYValue-Series1.MinYValue)/2;
  With ChartTool1 do
    Axis:=Chart1.Axes.Left;
    StartValue:=Series1.MinYValue;
    EndValue:=MidVal;
    EndVal:=EndValue;
  Chart1.Title.Text[0]:=FloatToStr(StartVal+((EndVal-StartVal)/2));
  ToolHeight:=(Chart1.ChartRect.Bottom-Chart1.ChartRect.Top) div 2;
  end
Yes, this is a problem I've been able to reproduce. I've added it to our defect list (TV52011105) to be fixed for future releases.
Maxc72
Post by Maxc72 » Wed Nov 30, 2005 12:50 pm
Hi, I'm sorry for bother you but i i've tried your code, and i think there was some misunderstanding, i must repruduce a graph like this:
and i must drag (left and rigth) the yellow vertical lines.
Massimiliano
Post by Pep » Thu Dec 01, 2005 4:27 pm
Hi Massimiliano,
one way to do this could be using the ClipRectangle method, in conjunction with TCursor Tools, this method will restric the Rect to display the Cursor. An example could be :
procedure TForm1.Series1BeforeDrawValues(Sender: TObject);
  Function SeriesRect(Series:TChartSeries):TRect;
    With result do
      Left:=Series.GetHorizAxis.IStartPos;
      Right:=Series.GetHorizAxis.IEndPos;
      Top:=Series.GetVertAxis.IStartPos+100;
      Bottom:=Series.GetVertAxis.IEndPos-100;
  With Chart1 do
       if CanClip then
          Canvas.ClipRectangle(SeriesRect( Sender as TChartSeries ));
procedure TForm1.ChartTool2Change(Sender: TCursorTool; x, y: Integer;
  const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
Charttool2.Repaint;
Another way to do this (which solves the fickering) could be a trick. It's to use a fake Series, adding the same data as the first Series, and creating a custom vertical axis for this Serie, setting the Start position to desired position you want that end the Cursor line. Then you only will have to asign the Cursor Tool to the fake series and hide the Axis and Series, you could use similar code like the following :
  // Series
  Series1.FillSampleValues(10);
  Series2.FillSampleValues(10);
  Series2.Color := clnone;
  Series2.ShowInLegend:=false;
// Custom vertical axis
with Chart1.CustomAxes.Items[0] do
  StartPosition:=50;
  Visible :=false;
  Series2.CustomVertAxis:=Chart1.CustomAxes.Items[0];
  // Cursor Tool
  ChartTool1.Series := Series2;
  Charttool1.Style := cssVertical;
