SilverLight Teechart - Candle series is plotted incorrectly
TeeChart Beta versions
Priya Hatipkar
Post by Priya Hatipkar » Fri Feb 27, 2009 5:57 am
SilverLight Teechart - Candle series is plotted incorrectly.
For same datasource, WPF teechart plots Candle series correctly.
Priya
Post by Narcís » Mon Mar 02, 2009 9:36 am
Hi Priya,
I'm not able to reproduce this here. Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
Priya Hatipkar
Post by Priya Hatipkar » Fri Mar 06, 2009 1:09 pm
To reproduce the problem, check sample 'Sample4ForTeechart.zip' uploaded at Steema upload site
Post by Narcís » Mon Mar 09, 2009 10:42 am
Hi Priya,
Thanks for the example project. The problem here is that it uses an ObservableCollection. It wasn't designed to work with series with more than two ValueLists. We will look into extending its functionality before the next beta release.
Post by Narcís » Tue Mar 10, 2009 3:35 pm
Hi Priya,
As an update, this has been implemented and the project you sent works fine now.
Priya Hatipkar
Post by Priya Hatipkar » Thu Mar 12, 2009 4:48 am
Thank you very much.
When this build will be released and will you publish it on the site?
Priya
