It would be usefull to have the option to make a chart istropic (chart aspect ratio in real coords space == chart aspect ration in pixel coords). For example on some charts ,i sometimes want the ratio of
A/B == C/D
where A = (chart.Axis.Left.Maximum - chart.Axis.Left.Minimum)
B = (chart.Axis.Bottom.Maximum - chart.Axis.Bottom.Minimum)
C = char.Axis.Left.CalcYPosValue(A)
D = char.Axis.Bottom.CalcXPosValue(B)
Moreover, I also need to be able to resize the parent window of the chart
keeping this ration constant. My reason for doing this is that if a contour
is a circle (for example section of a cylinder) I need (or customers need) to see it as a circle so that i can visually check that the contour is as expected. This would be really useful to have, as we have many cases where an engineer wants to look at a cross-section through a grid of surface data and would like to see the real cross section shape that was independent of the current display window size. I can see uses of this as and inspection tool for point clouds (reverse engineering, rapid prototyping and CMM)
Andrzej
would like isotropic axis scaling
Hi.
This feature has been implemented (and demonstrated) in TeeChart v7. Especially, check the "New Features -> New in Axis -> Isometric axes" example.
Marjan Slatinek,
