Hi Tom,
Whenever I export the TeeTree to svg format, I get the following error .
TeeTree v2 - What's New !
oops.
OK
Please let me know whether I am missing with any dll or any other thing?
Ashu
OOPS ---- ??
drop TeeSVGCanvas in your uses list and try the following code:
This should result in a part (100 by 100) image of your tree.
Tom.
procedure TForm2.Button38Click(Sender: TObject);
tmp: TSVGExportFormat;
TeeSaveToSVGFile(Tree1, 'c:\test.svg', 100,100);
Tom.
Hi Tom,
My Total bounds of the TeeTree are large (consider 1200x900 more or any thing else as it is not fixed).
I want to export it to SVG in full.
I am using the same method which you have suggested...
I am not sure but.. some times it works but some times it give the same error.. ie "Oops"...
Also... Image shapes are not exported to SVG?
I am not able see the image shapes in SVG file (when I was able to export the teetree in SVG format).
Ashu
Ashu
