LoadTreeFromStream- eternal loop- TeeTreeFindGlobalComponent
Posted: Fri Feb 23, 2007 11:49 am
by 9231208
Support,
I see this has come up before, but I did not see a solution.
I am using SaveTreeToStream & LoadTreeFromStream to copy the contents of one TTree to another, but I am getting an eternal loop in the 'TeeTreeFindGlobalComponent' procedure when calling LoadTreeFromStream.
Here is the sample code:
procedure TForm1.cmdStreamClick(Sender: TObject);
var
  msTemp: TStream;
  Form2.Show;
  Form1.TreeSource.NoOwnerShapes := False;
  Form2.TreeDest.NoOwnerShapes := False;
  msTemp := TMemoryStream.Create;
  try
    SaveTreeToStream(TCustomTree(Form1.TreeSource), msTemp);
    msTemp.Position := 0;
    LoadTreeFromStream(TCustomTree(Form2.TreeDest), msTemp);
  finally
    FreeAndNil(msTemp);
Form1 contains the source TTree and Form2 contains the destination TTree.
Kind regards,
Keith Blows
Posted: Fri Feb 23, 2007 12:50 pm
by 9231208
Found the problem- seems to be bug in that the component's name is saved with the stream, which causes a problem when trying to load it. This text must be removed from the stream. Here is a simple routine to handle it for you:
procedure FixedSaveTreeToStream(ATeeTree: TCustomTree; AStream: TStream);
var
  lTemp: TMemoryStream;
  lChar: Byte;
  lComponentNameLen: Integer;
  lComponentNameLen := Length(ATeeTree.Name);
  lTemp := TMemoryStream.Create;
  try
    SaveTreeToStream(ATeeTree, lTemp); // This saves the component's name in the stream, which causes problems when loading...
    // We need to delete the name from the resultant stream- it is located at position 11
    lTemp.Position := 0;
    AStream.CopyFrom(lTemp, 10);
    lChar := 0;  AStream.Write(lChar, 1);
    lTemp.Position := 11 + lComponentNameLen;
    AStream.CopyFrom(lTemp, lTemp.Size - lComponentNameLen - 11);
  finally
    FreeAndNil(lTemp);
var
  Form2.Show;
  try
    FixedSaveTreeToStream(TreeSource, lTemp);
    LoadTreeFromStream(TCustomTree(Form2.TreeDest), lTemp);
  finally
