TTree ConnectionPoints
SStone
Post by SStone » Fri Jun 17, 2005 10:30 pm
I have 2 TreeNodeShapes with a connection between them. I try and add some additional points to the connection. The added points appear but the end points are no longer "linked" to the Shapes. I've tried reassigning the ToShape,FromShape nothing. How can you progamatically reconnect the connection to the shapes ??
I'm missing something.
Sample Code.
nd : TTreeNodeShape;
nd2 : TTreeNodeShape;
cn : TTreeConnection;
cp : TConnectionPoint;
p : TPen;
t1.Designing := true;
nd := t1.Items.AddChild(nil,'Hello?');
nd.Style := tssRectangle;
nd.Top := 120;
nd.left := 120;
nd2 := t1.Items.AddChild(nil,'World');
nd2.Style := tssRectangle;
nd2.Top := 120;
nd2.left := 320;
cn := nd.addconnection(nd2);
cn.Points.add(cpsfixed,120,cpsfixed,120);
cn.Points.add(cpsfixed,220,cpsfixed,220);
cn.Points.add(cpsfixed,320,cpsfixed,120);
cn.Border.SmallDots := false;
cn.Border.Style := pssolid;
cn.border.width := 1;
cn.SimpleText := 'Stuff';
cn.FromShape := nd;
cn.ToShape := nd2;
tom
Post by tom » Mon Jun 20, 2005 11:14 pm
With cpsFixed you tell teeTree to put a point on a fixed x,y position.
You should use the following code:
  cn.Points.Add(cpsAutoFrom, 120, cpsAutoFrom, 120);
  cn.Points.Add(cpsPrevious, 100, cpsPrevious, 100);
  cn.Points.Add(cpsAutoTo, 320, cpsAutoTo, 120);
with cpsAutoFrom and cpsAutoTo you attach the connection to the From and To shape respectively. The provided x and y values are not really needed in this case, since they are set by the from and to shapes, however there is a slight difference, you can see this by using the following code instead (look ath the starting position of the connection):
  cn.Points.Add(cpsAutoFrom, 0, cpsAutoFrom, 0);
There are several other ways to add/insert points (you are not always obliged to proved a connectionpointstyle). e.g. If you create the third point at another moment, you can also use the following code (in this case we use the insert instead of the add method):
  nd.Top := 120;
  nd.left := 120;
  nd2.Top := 120;
  nd2.left := 320;
  cn.Style := csLine;
procedure TForm1.Button2Click(Sender: TObject);
  //one of the possible ways to select a connection
  cn := t1.Connections[0];
  //insert a point to the already existing code
  cn.Points.Insert(1, 220,220);
  cn.Repaint;
The different ways to specify the connection points coordinates:
 cpsAutoFrom           Automatic position on the "From" node
 cpsAutoTo             Automatic position on the "To" node
 cpsFromPercent        + / - percent on "From" size
 cpsToPercent          + / - percent on "To" size
 cpsFromRel            + / - pixels relative from "From" node origin
 cpsToRel              + / - pixels relative from "To" node origin
 cpsPrevious           + / - pixels relative to Previous Point in array
 cpsNext               + / - pixels relative to Next Point array
 cpsFixed              Fixed XY pixel position
Tom
