invisible node border becomes visible on scrolling
Posted: Fri Aug 15, 2014 12:38 pm
With TeeTree of TeeChart 2014 an invisible node border becomes visible on scrolling.
You can reproduce the problem by putting a TTree component on a form and adding the following code to the OnCreate event of your form:
Then, execute and scroll the tree to the middle.
For the moment, a workaround is to either set the node's Transparent property to true or setting the border's Visible property to true and the border's color to clWhite.
var
liI : Integer;
lxNode,
lxChild : TTreeNodeShape;
Tree1.Canvas := TTeeCanvas3D.Create;
lxNode := Tree1.AddRoot('Root');
lxNode.Border.Visible := False;
lxNode.ImageIndex := tiNone;
for liI := 1 to 100 do
lxChild := lxNode.AddChild(IntToStr(liI));
lxChild.Border.Visible := False;
lxChild.ImageIndex := tiNone;
lxNode.Expanded := True;
