Potential access violation after node creation
Posted: Mon Jul 14, 2014 11:48 am
by 16567585
In the TTree component of TeeChart 2014 of May,1 2, 2014, creating a node might result in an access violation in method TCanvas3D.AssignFont3D of unit TeCanvas.pas.
The reason is that method TCanvas3D.AssignFont3D misses a check whether the member View3DOptions is actually assigned. The following replacement for the method fixes the problem:
procedure TCanvas3D.AssignFont3D(const AFont:TTeeFont);
  if (not Supports3DText) and
     Assigned(View3DOptions) and
     (View3DOptions.ZoomText<>ztNo) and (View3DOptions.ZoomFloat<>100) then
       AssignFontSize(AFont,AFont.SizeFloat*0.01*View3DOptions.ZoomFloat)
       AssignFont(AFont);
Re: Potential access violation after node creation
Posted: Wed Jul 16, 2014 10:46 am
by narcis
Hi Collinor,
Thank you very much for your suggestion. It has been implemented in our sources for the next maintenance release.
