At first, the tree is scrolled beyond the top and the bottom if the top or bottom of the tree is reached.
Second, the zooming direction is inverted in contrast to the TTree component of TeeChart 2012.
Therefore, I changed TeeTree.pas, function TCustomTree.InternalWheel, in the following way:
procedure TCustomTree.InternalWheel(IsDown:Boolean);
var tmp : Double;
tmpFactor : Integer;
if IsDown then
tmpFactor:=+1
tmpFactor:=-1;
case FWheelNavigation of
wnSelection : if IsDown then
ProcessKey(TeeTree_DownKey,[]) // navigate one node down
ProcessKey(TeeTree_UpKey,[]); // navigate one node up
wnScrollVert : with View3DOptions do
// VertOffset:=VertOffset+tmpFactor*TreePageScrollQuantity;
// Avoid scrolling beyond top and bottom
if VertScrollBar.Visible then
if IsDown then
VertOffset:=Max(VertOffset-tmpFactor*TreePageScrollQuantity, -(VertScrollBar.Max - VertScrollBar.PageSize + 1))
VertOffset:=Min(VertOffset-tmpFactor*TreePageScrollQuantity, 0);
wnScrollHoriz : with View3DOptions do
HorizOffset:=HorizOffset+tmpFactor*2;
wnZoom : with View3DOptions do
tmp:=Math.Max(1,0.05*ZoomFloat);
// Ensure zooming behaviour of TeeChart 2012:
// to top downsize, to bottom enlarge
// ZoomFloat:=Max(1,ZoomFloat-tmpFactor*tmp);
ZoomFloat:=Max(1,ZoomFloat+tmpFactor*tmp);
