TeeTree VCL for Borland Delphi and C++ Builder.
BoikovSoft
Post
by BoikovSoft » Sun Nov 29, 2009 10:29 am
Hello!
I have found out very unpleasant error.
Do the following:
1) open the editor.
2) Create TTreeNodeShape
3) Establish values:
Left: = 0;
Top: = 0;
Height: = 1300 Pix (the figure height should be more heights of visible area of a window of the designer)
Width: = 1000 pix;
4) Click on an empty place (on the form)
5) Anew click Shape.
Result:
You will see spontaneous moving of object on a vertical.
Help to eliminate please this problem as it is possible faster.
BoikovSoft
Post
by BoikovSoft » Mon Nov 30, 2009 11:19 am
The problem disappears, when
Selected.ScrollToView: = false;
BoikovSoft
Post
by BoikovSoft » Mon Nov 30, 2009 12:49 pm
When you add TGridShape
Top: = 1000;
Also you scroll page downwards.
Instal on any cell focus.
Grid cells are incorrectly allocated.
The position of a strip of scrolling (at least Vertical) in method Draw is not considered.
Post
by Yeray » Tue Dec 01, 2009 2:22 pm
Hi BoikovSoft,
I've tried to reproduce it but couldn't. Please, try to prepare a simple example project we can run as-is to reproduce the problem here.
BoikovSoft
Post
by BoikovSoft » Wed Dec 02, 2009 5:16 am
Error modelling:
Var
obj : TGridShape;
Tree1.Designing := true;
OBJ := Tree1.AddShapeClass(0, 0,'', nil, TGridShape) as TGridShape;
obj.Top := Form1.Height + 10;
obj.Left := 400;
Tree1.HorzScrollBar.Automatic := false;
Tree1.VertScrollBar.Automatic := false;
Tree1.HorzScrollBar.Visible := true;
Tree1.VertScrollBar.Visible := true;
Tree1.Selected.ScrollToCenter := false; // If objects very big it is better to switch-off this option.
obj.Top := 10;
obj.Left := 400;
OBJ.Selected := true;
With mouse click cells of the top object, then bottom.
You will see, that Allocation of objects occurs not correctly and on a miscellaneous.
BoikovSoft on Wed Dec 02, 2009 6:06 am, edited 1 time in total.
BoikovSoft
Post
by BoikovSoft » Wed Dec 02, 2009 6:04 am
Here other error:
Var
tr: TTree;
obj : TTreeNodeShape;
r1, R2: TTreeRuler;
Tr := TTree.Create(Form1);
tr.Parent := form1;
tr.Align := alClient;
Tr.Designing := true;
r1 := TTreeRuler.Create(Form1);
r1.Parent := form1;
r1.Align := alTop;
r1.Tree := tr;
r1.Height := 20;
r2 := TTreeRuler.Create(Form1);
r2.Parent := form1;
r2.Align := alLeft;
r2.Tree := tr;
r2.Width := 20;
Tr.HorzScrollBar.Automatic := true;
Tr.VertScrollBar.Automatic := true;
Tr.HorzScrollBar.Visible := true;
Tr.VertScrollBar.Visible := true;
{ If objects very big it is better to switch-off this option.
This option works if it to establish in Design-mode}
//Tr.Selected.ScrollToCenter := false;
{When True - the Object is displaced in a bottom,
False - the object is not displaced.
It is easy for tracing, if in addition on the form to add rulers (TreeRuler)}
OBJ := Tr.AddShapeClass(0, 0,'qwerty', nil, TTextShape);
obj.Top := 10;
obj.Left := 400;
obj.Height := Form1.Height + 100;
obj.Width := 300;
obj.Border.Visible := true;
Now try to click on an empty place. Again on TTextShape. Again an empty place. Again on TTextShape. And so some times. On a vertical Ruler (R2) it will be visible as the object escapes downwards.
Post
by Yeray » Wed Dec 02, 2009 10:17 am
Hi BoikovSoft,
BoikovSoft wrote:Error modelling:
Var
obj : TGridShape;
obj.Left := 400;
obj.Top := 10;
obj.Left := 400;
This Allocation problem seems to be reproducible randomly with that code. I'll add this to the wish list to be fixed in future releases (TV52014581).
Also note that the demo at
What's New ?\Welcome !\Custom shapes\Grid shape looks stable.
BoikovSoft wrote:Here other error:
Var
tr: TTree;
r1, R2: TTreeRuler;
tr.Parent := form1;
r1.Parent := form1;
r1.Align := alTop;
r1.Tree := tr;
r1.Height := 20;
r2.Parent := form1;
r2.Align := alLeft;
r2.Tree := tr;
r2.Width := 20;
obj.Top := 10;
obj.Left := 400;
obj.Width := 300;
That's right too. Thanks for reporting it. I've also added this to the wish list to be fixed in future releases (TV52014582).
