TeeChart for .NET v2009 - Language file not complete
ATV
Post by ATV » Thu Jun 25, 2009 7:31 am
We use:
TeeChart
Latest Binary version: 20th May 2009 Framework 2.0 Build 4.0.2009.16183
If I open the Print dialog via "Chart.Printer.Preview();" the dialog appears.
The language is set to "German" via "Steema.TeeChart.Languages.German.Activate();"
Problem:
Not all string ressources are translated to german language:
For instance:
- Tab page: caption "Page"
- Caption "Margin Units"
- Tab format: 3 captions
Best regards
Thomas
Re: TeeChart for .NET v2009 - Language file not complete
Post by Yeray » Thu Jun 25, 2009 1:48 pm
Hi Thomas,
Thank you for reporting that. We'll try to fix it when possible. If you are in a hurry, we can send to you the translation file and you could correct it as you think it should be.
ATV
Post by ATV » Fri Jun 26, 2009 6:07 am
It would be OK, if this problem will be fixed with ne next build ...
ATV
Post by ATV » Mon Aug 10, 2009 9:48 am
I have downloaded an installed the last release from 30.6.2009 - but this simple bug is not fixed ... :-(
Post by Yeray » Mon Aug 10, 2009 2:27 pm
Hi Thomas,
I'm afraid that this is not as easy to fix for us as you think because we don't have any german speaking member in the steema corp actually.
So let me invite you to suggest us the proper way to do it as I've done before.
ATV
Post by ATV » Tue Sep 29, 2009 11:19 am
I am still waiting for a solution ...
It should be not a big problem to give some phrases to a proffesional translator if there is no in-house competence for this language (DE)
Post by Marc » Thu Oct 01, 2009 7:25 am
The text entries have been corrected for inclusion in the next maintenance release.
ATV
Post by ATV » Thu Oct 01, 2009 7:47 am
