Unable to get exact width of TchartControl.
Pradip
Post by Pradip » Thu Mar 12, 2009 1:06 pm
I had put t chart control on a Dockable Form. with dockStyle Fill.
when I try to acess its width it returns. default width which i had set @ design time.
it doesn't returns the exact width of Control. after docking.
How evever it return exact Width in after draw and before draw event.
i am using this width for some calculations. can u please help me how can i get proper width.
Post by Yeray » Thu Mar 12, 2009 1:40 pm
Hi Pradip,
This code seems to work fine for me here. Could you please try if it works as expected for you? Or could you please add the necessary changes to reproduce it?
  before = tChart1.Width.ToString();
  after = tChart1.Width.ToString();
  tChart1.Header.Text = "before: " + before + "   after: " + after;
Pradip
Post by Pradip » Fri Mar 13, 2009 7:53 am
HI Yeray,
i tried your code but it didn't worked.
actually the Tchart is on a usercontrol and that usercontrol is used on dockable form.
Post by Yeray » Fri Mar 13, 2009 3:46 pm
Hi Pradip,
I can't reproduce your problem. Please, could you send us a simple example project we can run "as-is" to reproduce the problem here?
Pradip
Post by Pradip » Mon Mar 16, 2009 11:42 am
hi Yeray
here is the code
private void InitializeComponent()
this.tChart1 = new Steema.TeeChart.TChart();
this.SuspendLayout();
// tChart1
this.tChart1.Aspect.ZOffset = 0;
this.tChart1.Location = new System.Drawing.Point(0, 0);
this.tChart1.Name = "tChart1";
//this.tChart1.Size = new System.Drawing.Size(672, 346);
string before = tChart1.Width.ToString();
this.tChart1.Dock = System.Windows.Forms.DockStyle.Fill;
string after = tChart1.Width.ToString();
this.tChart1.TabIndex = 0;
// Form1
this.AutoScaleDimensions = new System.Drawing.SizeF(6F, 13F);
this.AutoScaleMode = System.Windows.Forms.AutoScaleMode.Font;
this.ClientSize = new System.Drawing.Size(672, 346);
this.Controls.Add(this.tChart1);
this.Name = "Form1";
this.Text = "Form1";
this.ResumeLayout(false);
please let me know what is going wrong
Post by Yeray » Mon Mar 16, 2009 12:50 pm
Hi Pradip,
Are you writing code directly to the Form1.Designer.cs?
To view the values before and after the changes, you should see them in runtime, so try the code to the Form1.cs.
