0 values not shown in line series
AndreAtDeltares
Post by AndreAtDeltares » Wed Aug 20, 2008 11:42 am
Hi all,
The following code does not display the first point on my PC when the Y value of this point is 0.0, but does so when the value is 0.00001. On the PC of my co-worker it does. Both using VS 2005 and TeeChart 3.5. Any ideas?
André Hendriks
Deltares
            double?[] X = new double?[] { 0.0, 1.0, 3.0 };
            //double?[] Y = new double?[] { 0.000001, 1.0, 1.0 };
            double?[] Y = new double?[] { 0.0, 1.0, 1.0 };
            TChart c = new TChart();
            c.Dock = DockStyle.Fill;
            c.Aspect.View3D = false;
            c.Axes.Left.Automatic = false;
            c.Axes.Left.SetMinMax(-0.1, 1.1);
            c.Axes.Bottom.Automatic = false;
            c.Axes.Bottom.SetMinMax(-0.5, 3.5);
            Steema.TeeChart.Styles.Line l = new Steema.TeeChart.Styles.Line(c.Chart);
            l.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
            l.Pointer.HorizSize = l.Pointer.VertSize = 3;
            l.Pointer.Visible = true;
            l.Add(X, Y);
            this.Controls.Add(c);
Post by Pep » Thu Aug 21, 2008 10:18 am
Hello André,
you're correct, I've been able to reproduce the problem here using the latest release. It's a bug, it seems only happens trying to add data arrays directly to the Series. It has been added on our defect list and a fix for it will be considered to inclusion in one of the next maintenance releases.
As a workaround you could iterate through the arrays and add data using Add method :
l.Add(X[0], Y[0]);
