Saving Charts
NewbieSIM
Saving Charts
Post by NewbieSIM » Wed May 12, 2004 9:54 am
I'm trying to save my charts with the series on custom axes. The .ten file only allows you to save this as templates ie. if you open up a chart from a .ten file the series no longer is associated to the custom axes. How do you open a .ten file with its series still connected to your custom axes?
Post by Pep » Thu May 13, 2004 4:00 pm
Yes, this information is not saved in the .ten files. I've added this on our defect/wish list to be considered to inclusion in the next maintenance releases.
In menatime the only workaround if to reasign them again once the Chart has been imported.
NewbieSIM
Post by NewbieSIM » Fri May 14, 2004 6:59 am
Thanx for your help.
Just one more question...so what you basically saying is that there is no way of saving a .tee file from the tchart .net component, only .ten files?
Post by Pep » Fri May 14, 2004 10:41 am
Yes, the .tee fies aren't compatibles with the TeeChart for Net components.
Post by Christopher » Fri May 14, 2004 11:10 am
Hi --
OK, I've been able to reproduce this one here and have incorporated a fix to it in the next maintenance release, which will be due out shortly.
Thank you!
http://groups.google.com
http://codenewsfast.com/
NewbieSIM
Nexy Release
Post by NewbieSIM » Mon May 17, 2004 8:50 am
Hi...
When will the next version be released? We need to know so we can plan ahead.
Also will it store mutiple custom axes for mutiple series on one chart?
Thanx
Post by Christopher » Mon May 17, 2004 2:03 pm
Hi --
The version will be released before the end of next month.
Yes, it will store multiple axes for multiple series.
Thank you!
